engine modifications
Old Oct 15, 2012 | 11:29 PM
  #41
newpony's Avatar
newpony
Originally Posted by cmc87
If properly cammed, no. I mean, you don't want to go with HUGE heads, but 185-190cc with a matching cam will be some real fun, contrary to general belief. Then you can always plop them down on a larger displacement motor later
cool thats an answer i was looking for. now im hunting for some beasty heads 185s or better.
know of any that are budget friendly
Old Oct 16, 2012 | 12:23 AM
  #42
Duncan_GT's Avatar
Duncan_GT
you don't want to go with HUGE heads, but 185-190cc with a matching cam will be some real fun)
I agree. I have a buddy who had Victor Jr's (205cc) on his 306. That thing was sluggish and dragged ***, even with 4.10's.
185's would be the biggest I'd go on a 302
Old Oct 16, 2012 | 01:27 AM
  #43
newpony's Avatar
newpony
Well it will be a street car so i wont need the power until i need the power.Will larger the 185s loose hp?
and looks like afr has the largest carb/50 state legal heads. are there any others ? I thought i seen some trick flows the were larger than the 170s some where.
Besides the carb/smog looking at windsor sr's ,trickflow.
Old Oct 16, 2012 | 09:00 AM
  #44
89fiveeight's Avatar
89fiveeight
No. Youre going to spend $1400 on the low end. Do it though. it's worth the money. Good heads are definitely one thing where you get what you pay for.
Old Oct 16, 2012 | 05:01 PM
  #45
Duncan_GT's Avatar
Duncan_GT
In simple terms, a larger head on that size motor will move air slower at lower rpm's. You'd have to spin that thing pretty high to take advantage of the larger intake cc. With a smaller type head, air will move quicker.
To directly answer your question, yes you would lose horsepower if your motor isn't built to rev up that high.
Old Oct 16, 2012 | 06:50 PM
  #46
Venomantidote95's Avatar
Venomantidote95
Dont get the big boy syndrome! fair warning...... ^^^^^^^^^^^^ you have just been given a very correct statement! Dont buy ahead, wait save your money, get the entire 351w setup, then swap if that is where you are going!
If you dont you will be needing that sledgehammer you mentioned!
Old Oct 17, 2012 | 09:12 PM
  #47
newpony's Avatar
newpony
Thanks much for the insight thus far , i made a thread a while back and didn't get much far.
Well talking about bottom end and limits any budget block out there that will withstand 500+hp (which seems to be the upgrade point)that could take some high revs. 302,332-347s too be specific?
The 351w thing may get pushed back a bit more,although i have talk to this guy who has a 92 efi , not sure if i mention it earlier or not. I was planning on getting it in the next couple days(could have gotten it last week), i still want to grab it and start the swap swap. Its much of the reason why i asked if ill gain from it .
So yeah im a bit caught up here but i do think myself that after whats been said getting the 351w now should be a good choice 1 good reason its basically getting a stroker .
Is there short tubes i can run. The long tubes are not exactly 50 state legal?
the motor has the stock shorties on it in sure they are a bit restrictive . i have flow masters and my buddy has built a custom exhaust for one of his 351 swaps already and i think he is running shorties but aftermarket.
Old Oct 17, 2012 | 11:15 PM
  #48
newpony's Avatar
newpony
i just about done with trying to get teh stock block to/past 7krpms i thought id need the bottom end balanced and the engine to breath up there seems im wrong ??correct me if you know something id like to know.
Also not looking to do a chevy swap, rather just go with 351w , & ill geta camaro or corvette before a chevy swap, thought about it and i have an extra roller. (if i think reviving it is worth it and can find a chevy drive train for cheap enough well t hat may be a project)
Old Oct 18, 2012 | 12:22 AM
  #49
tinman's Avatar
tinman
There are some long tube headers that are 50 state legal......
I think BBK is in fact.
Old Oct 18, 2012 | 12:48 AM
  #50
bluebeastsrt's Avatar
bluebeastsrt
My understanding is there are no long tube and only a few shorty carb legal headers out there. If your not in califorinia alot of other state will pass you as long as you dont remove the cats. Theres ways around the whole inspection sticker thing.
