2012 GTCS- full exhaust question
#21
I would think an X-pipe will get you better flow, sounds a lot better IMO too. I would try to have a full 3" all the way through. It's costly, but it would be worth it. I've got a little over 2 grand in my exhaust (headers, x-pipe, and axle back).
#22
Okay. So lets say i get heartthrob straight pipe with the X. How do i mount borla axle backs to the 3 inch pipe (borla has 2.75inch inlet!!)? Been racking my brain and kind of embarrassed if it is an easy fix lol.
#23
If you start getting into exhaust diameter changes from different manufacturers you are going to have to get a muffler shop to modify it and install it. Assuming you are just having them put adapters on it it will probably run about 200. Also I don't think that 3" exhaust is necessary for non-FI applications. Yes you gain some at your peak range but you loose a lot more over the rest of the curve. If someone has some dynosheets that show otherwise post them up.
#24
Dont think i will do FI with this high of compression motor. Besides, i played with a procharger on the Cobra which was fun, i think i want this all N/A.
#26
That was Mustang 5.0's speculation. This is why regardless i would cut out the resonators. Either way 2" or 2.75" i dont like it lol.
Just trying to decide how i will set the exhaust up. Decisions Decisions...
