5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
P0345 code
Old Mar 29, 2019 | 03:59 PM
hkerekes's Avatar
hkerekes
Default P0345 code
Its a 2012 Boss 302 it seems to run fine but definetly feels down on power in the upper rpm sometimes. Threw a p0345 about a month ago so i swapped both cam sensors to the passenger side. P0345 came back a few weeks later.
Sensor A bank 2 is the drivers side intake sensor?
All 4 vct sensors ohm out the same. I havent pulled the valve cover to check the screens or the cam phaser.
I assume its a wiring issue going back to the pcm.
Any ideas?
Old Apr 1, 2019 | 02:15 PM
Derf00's Avatar
Derf00
Gentleman's Relish
P0345 is most commonly linked with a failing alternator on these cars. When the alts rectifier starts to fail, it throws out a squared sine wave that interferes with the Cam sensor signal so, the computer thinks it's a cam sensor and spits out P0345. The alternator is probably charging fine but it's on it's way out (actually already gone out) since you have that code.
Old Apr 1, 2019 | 04:25 PM
hkerekes's Avatar
hkerekes
I have a coyote based boss 302. I don't think the alternator problem affects these like the 05-10 mustang
Old Apr 1, 2019 | 06:03 PM
Derf00's Avatar
Derf00
Gentleman's Relish
This seems really dumb but...how's the oil level?
https://www.svtperformance.com/threa...ailure.910736/
Old Apr 1, 2019 | 06:49 PM
hkerekes's Avatar
hkerekes
Fine, I actually just changed the oil. I'm going to yank the valve cover tomorrow and swap the vct sensors and check them for any crap in the screen.
If the same code comes back I guess I have a bad cam phaser. At that point I might throw in a set of cams.
Old Dec 27, 2024 | 08:02 AM
Br8ton71's Avatar
Br8ton71
Default P0345 alternator
Does the alternator theory apply to the 2015 gt's I can't find anything relating it to these cars?. I got the cam sensor codes
Old Dec 27, 2024 | 03:36 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
mustangfan777
Oct 23, 2015 10:31 PM
redskins87
Sep 5, 2014 10:25 AM
kd3608
15
Jul 18, 2011 07:27 PM
98sleeperGT
May 18, 2008 02:55 PM
Casper1
Feb 22, 2007 12:40 PM
