Warranties
Old Feb 3, 2007 | 03:10 PM
jtstudley's Avatar
jtstudley
Default Warranties
I have a 8w7 with a factory warranty. It says the warranty is void at 500ish Watts. If I have a 350ish amp and my sub blew for some reason, would I easily get another sub for free. How do you prove that you played the sub below the cut off point?
Old Feb 3, 2007 | 06:03 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: Warranties
Keep in mind, you can blow ANY speaker with ANY amp. If you send a dirty signal to the sub, you will blow it up. I don't know of any way to prove you didn't clip the signal. Too bad the speakers don't have the same type of set-up the NASCAR rides have to prove the car exceeded the RPM range of motor
Sorry for your prob. Good luck.
Jazzer
Old Feb 5, 2007 | 09:03 PM
jtstudley's Avatar
jtstudley
So how would you go about getting a new sub if yours broke? Has anyone taken advantage of their warranties (or tried)?
Old Feb 5, 2007 | 10:08 PM
Jazzer The Cat
Retired Moderator
Contact the carrier of the warranty, andsee what they say. They just may look at the rating of amp/speaker and hook you up with a new sub. I have been running high power stereos for many years and have not blown any speakers up, so not sure what I would do other than above if had a prob.
Jaz
Old Feb 5, 2007 | 11:12 PM
ttocs's Avatar
ttocs
you can blow a speaker with too little power easier then with too much power. When you send it a weak signal it will start to "clip" alot sooner. "Clipping" is when the top of the sign wave(music) gets cut off and instead of being a smooth curve, becomes a straight line. Now instead of sending your speakers AC(alternating current or music in this case) you are sending it DC(Direct current) and nothing could be worse for a speaker. It would be the same as hooking you speaker up to the battery. It will move to its furthest limit either forward or backward for a second, then start to smoke.
jerrytubes
Oct 23, 2015 12:11 PM
KingRando
Oct 2, 2015 08:06 AM
tmdm
Sep 17, 2015 08:51 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Art161
Sep 9, 2015 10:33 AM
