quick audio upgrade HELP
Old Jul 13, 2007 | 01:02 PM
  #21
seight311's Avatar
seight311
Default RE: quick audio upgrade HELP
Don't get the cheapest, certainly do not get the most expensive.
Totally agree
Old Jul 13, 2007 | 03:49 PM
  #22
sandcracker21's Avatar
sandcracker21
well. the wire is already in there, although i can not find it in the engine bay at all
if my budget was 300$ and all i want to add to my car is more UMMMP with base, what route should i take?
Old Jul 13, 2007 | 08:53 PM
  #23
PReal's Avatar
PReal
A couple things guys.
Wire is wire. I have used 2 and 4 gauge oxygen free welding wire on a couple installs and it is way better then anything else I could find for the cost per foot.
For signal wires wire is wire, but the poorer quality wires have less insulation, more resistance, and are more likely to cause alt whine.
SANDCRACKER SEIGHT GAVE YOU A LIST OF LIKE 5 OPTIONS THAT WOULD BE GREAT!!!!!!!!
Old Jul 15, 2007 | 08:35 PM
  #24
sandcracker21
Thanks for all the input, my friend has this particular package in his car and I was just wanted to double check this would work out in mine.
http://www.crutchfield.com/S-1v5LJXF...mp;I=700TCRT12
Thanks for the input and advice so far, I was thinking of gettin this and going to work to see if I cant install it myself.
Old Jul 15, 2007 | 09:27 PM
  #25
PReal's Avatar
PReal
That package is garbage for the money. Look at the list of equipment seight gave you, they will blow that setup away!!!!
Old Jul 16, 2007 | 04:03 PM
  #26
y2kStangGT's Avatar
y2kStangGT
When i first purchased the car, i brought it to circuit city and the guys there told me the same crap. They need to rewire everything and wanted $900 for a 300W bazzoka sub and amp including the installation. So what i did was ordered my Pioneer HU on ebay along with kicker amp and sub. I also ordered the installation kit (12v cable, rca cable, speaker wires, etc). I did it myself on a sat. afternoon. The installation was easy. You don't have to rewire anything. I think maybe my car already had an after market HU but it was old. I just connect the the harnesses together. when you buy a new HU, there should be a manual or instruction booklet that you can follow. the hardest part for me was drilling a hole through the firewall. that was a paint in the ***. Also, running the wires from the amp to the HU is also time consumming. Don't ever listen to those suckers at CC (circuit city)or BB (best buy).
Old Jul 16, 2007 | 04:08 PM
  #27
y2kStangGT's Avatar
y2kStangGT
ORIGINAL: PReal
+1
this setup is garbage.
I purchase my kicker amp and sub on ebay for less than that
Got a zx400.1 amp and a 10'sub with 400rms watts.
I think my setup is way better than what you listed and it's a little less than 299.
Plus dual 12' will be tough to fit into your trunk. You will have to remote the amp rack along with the 460 amps.
Old Jul 16, 2007 | 08:21 PM
  #28
seight311's Avatar
seight311
Way better than what?
And...
What?
Old Jul 16, 2007 | 10:40 PM
  #29
y2kStangGT's Avatar
y2kStangGT
[quote]ORIGINAL: seight311
way better than this http://www.crutchfield.com/S-1v5LJXFsd7L/cgi-bin/prodview.asp?g=208250&I=700TCRT12
Old Jul 17, 2007 | 10:12 AM
  #30
PReal's Avatar
PReal
ORIGINAL: y2kStangGT
ORIGINAL: PReal
+1
Kicker is OK equipment, but I would not recommend your setup over any of the setups seight mentioned.
