ohms
Old Aug 18, 2007 | 02:30 AM
jakeachy's Avatar
jakeachy
Default RE: ohms
2 ohms is less resistance than 4 ohm. less resistance= more power.i dont want to get into the fundamentals of electricity's nature at 2 am.
Old Aug 18, 2007 | 02:45 AM
Allstar's Avatar
Allstar
Default RE: ohms
im going to draw up a diagram of what oim getting from this right now u tell me if what im doing is right
Old Aug 18, 2007 | 02:52 AM
Allstar's Avatar
Allstar
Default RE: ohms
Is this anywhere close?
[IMG]local://upfiles/17054/8869281FAC454836B143E6CF9D0A2AC9.jpg[/IMG]
Old Aug 18, 2007 | 02:54 AM
Allstar's Avatar
Allstar
Default RE: ohms
sorry im coming off as a complete retard with this normally im good with this stuff i just want to get a good understanding im more of a computer and car person not really all that educated in audio that well as u can see
Old Aug 18, 2007 | 03:00 AM
jakeachy's Avatar
jakeachy
Default RE: ohms
your using a mono amp? that diagram is wrong. use my picture, do that to each sub. then connect the negative wires to the amp together, and same with positives. you need both negetive wires into the negative terminal and both positives into the positive terminal in the amp. your diagram is actually 8 ohm i think, but ive never done anything over 4, as its useless.
Old Aug 18, 2007 | 03:04 AM
Allstar's Avatar
Allstar
Default RE: ohms
ok i think i got you but just to make sure im going to take a long shot here
basically ur diagram ur saying is the same as this one am i right? and thisis what i need to do, correct?
[IMG]local://upfiles/17054/DE4C5E105EFB45D38942BBBD2BDC5372.jpg[/IMG]
Old Aug 18, 2007 | 03:09 AM
jakeachy's Avatar
jakeachy
Default RE: ohms
the diagram you have showed will be what you want.
my way is a 2 ohm load where your diagram says 4 ohm. so technically my way is 1 ohm, but then again its not. your diagram is good.
Old Aug 18, 2007 | 03:12 AM
Allstar's Avatar
Allstar
Default RE: ohms
thank you so much for your help haha im still a little confused by the diagram u made i dont know why but now i know what i need to do which is whats important to me ahaha
i appreciate your time
SteelerNation82
Sep 16, 2015 07:11 AM
skm52670
Mar 27, 2006 05:33 PM
Dark_Horse
Dec 18, 2005 05:40 AM
baddog671
Oct 20, 2005 03:59 PM
Cogtx
Aug 31, 2005 08:39 PM
