CD Player Wiring Connector Problem.
Old Feb 14, 2009 | 03:14 AM
octain01's Avatar
octain01
Default CD Player Wiring Connector Problem.
I bought a car stereo wiring connector for my 2000 GT. I went to install it, and noticed all the plugs weren't there. I checked to make sure I bought the right one, and sure enough, it says it will work with a 2000 mustang. I then done some research and found that If you have the mach 460 sound system, you need a special wiring harness for it. I was wondering if this was true, and if it is, where can I get the special wiring harness I need?
Thanks!
Old Feb 14, 2009 | 09:01 AM
ttocs's Avatar
ttocs
if you have the standard ford hrns already(70-1770 or fdo1b) then you will need an additional hrns to get the subs to play. Page 2 of my cardomain page shows how I put an alpine in my mach system. It does not have to be as hard as I made it as I tweeked it for a little while afterwards(added caps to take the bass out of the tweets) and was suprised how well the stock system could sound.
Old Feb 15, 2009 | 03:45 AM
octain01's Avatar
octain01
Ok, got them installed. found the right wiring harness at Auto Zone. The only problem I am having now, when I turn the CD player on I get this high pitched squeak. It only happens when I turn it on, then it immediately goes away. Any suggestions on what could cause this? I must note, It sounds great! Just hearing this high pitched squeak every time I turn it on gets annoying.
Old Feb 16, 2009 | 12:00 AM
ttocs's Avatar
ttocs
the sound goes away? it is not determined by the engine rpms?
What kind of radio is it?
Old Feb 16, 2009 | 01:39 AM
octain01's Avatar
octain01
Nope, engine RPM's don't bother it. Just when I turn it on (the CD Player), it makes that noise, then goes away. Its a Pioneer. I'm not too worried about it since it only does it for a second, but I would like to find out why its doing it.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
