Custom Sub Box
Old May 30, 2009 | 01:14 AM
inukiller5's Avatar
inukiller5
Default Custom Sub Box
Hey does anyone know where i can get 2 sub boxs for a 12" sub. that will mount on the sides of the trunk... like in front of the taillights?
thanks
Old May 31, 2009 | 05:30 PM
baddog671's Avatar
baddog671
Make your own. If you are looking for just a simple sealed box, it isn't hard at all...
Old Jun 2, 2009 | 01:24 PM
JayMax03's Avatar
JayMax03
either that or ebay
Old Jun 2, 2009 | 02:20 PM
TotoGT06's Avatar
TotoGT06
never do ebay, do it yourself or youll have to pay to have someone do it. It really isnt hard at all. If you can cut wood, glue, screw, drill, draw, measure, and work with hand tools, it is not hard at all.
Start out by making templates for the base, then cut your piece out of 3/4" MDF board. after you get that, just start making every side, glueing, screwing, and cutting. If you had a S197 I would have done it for ya
Plus the subwoofers you have will ultimately determine how much space should be on the inside of the box, too little or too much space will not make your subs sound good. Thats why prefabed boxes can not be trusted for the right sound. It will work but wont sound as good as it should
Old Jun 2, 2009 | 07:00 PM
pentavolvo's Avatar
pentavolvo
nothing wront with a quality prefabbed box pending it matches ur airspace
Old Jun 4, 2009 | 04:22 PM
baddog671's Avatar
baddog671
Figure out what sub you want first so you know the correct cubic feet you need in your box. Do the math to figure out your internal and external volumes (if your dimensions equal 2ft^3, it isn't actually that becuase the boards take up room, it would be less internal..). Make a box out of cardboard to make sure it fits correctly in your trunk. Then make the box with MDF
Old Jun 10, 2009 | 11:53 PM
Iskwezm's Avatar
Iskwezm
Bassforms makes pre fab fiberglass boxes to fit there.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
mdg
Oct 1, 2015 07:04 AM
