static issue
Old Mar 15, 2010 | 02:15 AM
bstevems39's Avatar
bstevems39
Default static issue
got 4 alpine spr-13c in my car run off alpine 4 channel amp.
when i have the volume turned off or down on my deck(pioneer avic-f700bt) there is still static coming through the speakers slightly. is this normal or could there be a problem that needs addressing.
**not sure if the static is still there when i turn it up because the music would drown it out.
Old Mar 15, 2010 | 01:09 PM
ttocs's Avatar
ttocs
try turning the gain on the amp down a bit and see what happens.
Old Mar 15, 2010 | 06:04 PM
JayMax03's Avatar
JayMax03
no thats common with the AVIC-F series turning the gains would help a little but the problem would still be there you might have to get some noise filters
Old Mar 15, 2010 | 06:29 PM
bstevems39's Avatar
bstevems39
turned the gain down, reduced the noise alot to the point it doesn't bother me. thanks 4 the help
will have a look into noise filters see if it eliminate the problem
Old Mar 15, 2010 | 09:09 PM
ttocs's Avatar
ttocs
what is the gain set to now? IT should never need to be more then 3/4 full.
Old Mar 16, 2010 | 12:24 AM
bstevems39's Avatar
bstevems39
its half way, not sure exactly what it set at but i set it to the middle where it says nom assuming that means normal.
another question hp lp filter what should those be set at 4 my speakers any idea?
having trouble getting it set back up on my deck had a custom tune and when i diconnected my battery everyhting erased. can't seem to get it back to how it was.
Old Mar 21, 2010 | 11:26 PM
ttocs's Avatar
ttocs
HP = high pass = all high freqs that would go to a mid/tweeter pass through, bass is stopped
LP = low pass = all the bass freqs that should ONLY go to a woofer pass through and treble is stopped.
For full range speakers, if you are not using a sub you will want to not use any cross over as then nothing will be playing bass. IF you have a sub then flip all the rest of the speakers to HP so that they can play what they like, and the sub can do its job.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
