JL Stealth box in a s197?
#51
I havent been down to update htis in a while, stuff was installed a few weeks ago:
https://mustangforums.com/forum/2005...-tomorrow.html
I love the thing, the 10 and 11 are the same body wide it should fit. It sounds great.
#52
if you are going into sound quality competitions then you would want the clean sweep. The adapter from PAC is doing the same thing that the cleansweep is doing, just a whole lot cheaper. IF you don't want the bass in the front of your vehicle, then you should disconnect the sub in the door. The 8" sub you are looking at is not the right sub to put in the door. You should use a shallow mount woofer like the Kicker 8 CVT.
#54
Dumb question here...
I looked through the site to see if that would work with the 2011 w/ Shaker but didn't see any info on it. Customer service is closed today (sunday). Do you know if it's compatible? I'd really like to get some good low end funk back in the trunk because the stock shaker system sounds as bad as the Blose System I had in my C6.
Thanks,
DJ
Thanks,
DJ
#55
Another question for you guys... if the stock shaker 500 comes with what is basically 2 8" woofers in the front doors (aside form the component/coax speakers (never seen what it looks like with the door card off so i'm not sure wahts behind there)
If you replaced the two 8" woofers with some quality stuff.. JL 8W3's for example, would a sub in the trunk really be necessary?
I can't imagine the door has the proper enclosures needed to really make them produce good sound either though...
Would it make more sense then to just put a set of compenent 5x7's in the door and a set of 5x7 Coaxials in the rear followed by that 13w3 in the stealthbox in the trunk? doing away with the 8" drivers in the door altogether?
Also just as an update for you all... now that I actually own a Mustang, I contacted scosche today looking for an update on their kit... they say they are 95% sure it will be released by the end of January... so who the hell knows... they say expect an MSRP of around $300 as well. - Fully customizable for cars with and without dual climate and for cars with or without heated seats.
#56
yeah i saw that kit, i dont realyl like the looks of it. i like the scosche one, but honestly I'd rather keep it looking stock inside at least for now. I woudln't mind a touchscreen nav system, but I LOVE sync and that will kill sync control. That's mostly why i want to keep the stock radio.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
