PAC FRD04 Aux input install... need help
Ok, so I got the PAX FRD04 aux audio input for my Shaker 500 in my 2006 Mustang.
I've got the dash all apart no problem.
I've Got the radio out, hooked up the interface between the radio and factory connector.
I've got a power source to the PAC from a "on with the key" fuse from the passenger side.
Put everything back together. Turned on radio, all speakers work. (Hurray!)
Hit Aux input on the Shaker 500.
Shaker 500 tells me "no aux input"
What did I do wrong? Do I need a better ground?
unlpug the FACTORY radio plug from the harness(leaving the AUX input plugged into the radio) and let the radio sit for about 5 minutes to reset.Reconnect the factory radio plug,turn the radio on,push the AUX button and see if it works.
Unplug the negative terminal of the car battery , that way there is no need to take the radio apart again
the first time the radio gets power, after is been unplug for 10 minutes it search for devices plug into the radio, most likely this will solve the problem
The next time I started the car, it didn't work. So I took the dash apart and unplugged the harness and plugged it back in again. ... it worked.
The next time I started the car, it didn't work. So, today I took the dash apart again, and unplugged the harness.... and returned it.
Maybe I can find a Shaker 500 from a 2008 stang with the aux input built in... or maybe a Double Din Nav Receiver.
After relocating the ground, I did this. The PAC worked. Hurray!
