Install Components?
Old Jan 20, 2011 | 09:26 PM
HT's Avatar
HT
Default Install Components?
So, I have my parts ready to go. I have a Pioneer Z-120BT and my Magden M1.b Performance Computer.
Wayne, you linked me to that PAC harness kit. Is that what I want instead of the regular harness? Or how do I use that?
Do I need anything else?
I know I need a dash kit too, but I'll get that. I meant electronics wise for the install.
Old Jan 22, 2011 | 01:04 AM
wayne613's Avatar
wayne613
Instead of. The usual writeups are using the metra/scoche ones, which you donīt want if your looking for a crimp and go bolt-in solution.
You might need a diode to prevent an reboot issue with some pioneer units and the PAC unit. Iīd just do it ahead of time to save yourself the headache.
As for being set, only other things really are heat-shrink tubing, solder and 15w soldering iron if going that method, or crimp connectors and crimping tool for that method. Otherwise unless you have some special HDMI connection to use for the magden, you should be good.
Maybe a relay if your looking to have dvd playback while driving for any passenger you might cart along. Thatīs about it.
Old Jan 22, 2011 | 01:19 AM
HT's Avatar
HT
Okay. I'm looking to skirt the parking break lockout, for the sake of the Magden mainly.
Old Jan 22, 2011 | 01:27 AM
wayne613's Avatar
wayne613
See my posts here. This might still use the VSS though to lock you out without doing the main bypass method(shown in below youtube vid). *shrug*
So, you just a 1-amp diode (1N4005) from Radio Shack left after the PAC if you do the below bypass method. This is to prevent this issue from occurring.
[youtube]D3_GvJ7ACbk[/youtube]
Old Jan 22, 2011 | 01:35 AM
HT's Avatar
HT
I think I might take it to a local audio shop and work with them to get all this done. I really want to learn how to do it, but I'm scared I'll screw something up because I've never messed with it before.
Old Jan 22, 2011 | 01:40 AM
wayne613's Avatar
wayne613
If you do have them do this, make sure they get a printout of that PAC issue. It doesnīt happen to everyone, but Iīve seen it in a couple of recent threads now.
Most of the time, if you have some electronics experience at all itīs far more likely THEY will screw something up, then you. Most stereo install places are kids getting a paycheck for grunt work. Everythingīs on a tight time-table, everything is crimped and taped(if your lucky), and they donīt give a damn about your car. Theyīre only interested in getting it hooked up and functioning for the short-term.
Thereīs not a single one around here I know of that isnīt the equivalent of a fast-food drive through for car installs. I wouldnīt trust them installing a valve-stem cap, much less a complete head-unit.
Old Jan 22, 2011 | 01:49 AM
HT's Avatar
HT
Yeah, I have a guy that I really trust locally. He is really reputable, but I'll have to tell him exactly what I want to work and how and lead him through it.
As far as electronics experience, I've built my own PC. Never soldered anything, or anything of that sort, but it can't be too hard...I'm just scared to screw something up.
Can you link me to the PAC issue? I have no idea what you are talking about there.
Old Jan 22, 2011 | 01:51 AM
wayne613's Avatar
wayne613
I put a link in 2 responses to the pdf file for the issue. And now, again there.
Originally Posted by from above pdf file
PROBLEM: In some cases, Ford amplified systems may cause feeback to the C2R-
FRD1 module and cause the radio to turn off intermittently or restart especially at higher
volumes.
FIX: Cut the White/Green wire coming from the C2R-FRD1 module and solder a 1 amp
diode (Radio Shack part no. 1N4005) or equivalent, inline on the white/green wire as
shown in the diargram below. Make sure that the diode’s stripe is towards the harness
of of the C2R module.
They need some grammar police and some spell-checking software there, but..
Old Jan 22, 2011 | 01:56 AM
HT's Avatar
HT
Oh cool. I have seen that. The diode installation was in the stickied 3200DVD install thread, I just didn't know that those two things were one in the same.
Old Jan 22, 2011 | 02:03 AM
wayne613's Avatar
wayne613
That part list, and even the write-up itself should be the exact same thing for your unit. Even the colors for the wires are likely the exact same.
If you use a hair-dryer for the heat-shrink tubing I may need to drive down to pimp-slap you however. Waving motion while rolling the wire slightly with a bic lighter and done.
