headunit bridging
Old Jan 11, 2006 | 10:48 PM
p0rsche23's Avatar
p0rsche23
Default headunit bridging
is this possible? like hooking up the rear speakers to an amp and then bridging the front speakers from the headunit so that it sends 100x2 instead of 50x4....? I dont see why it wouldnt but maybe not....
Old Jan 11, 2006 | 10:57 PM
pj1010's Avatar
pj1010
Default RE: headunit bridging
You may be able to. I think in doing so, you might open the door for a problems. My recomendation would be stick the amp on the front drivers and leave the rear drivers alone. Your HU will be able to provide some decent RAF.
Old Jan 12, 2006 | 03:34 AM
seight311's Avatar
seight311
It's definatly something no-one here with a reputable opinion would suggest. I myself would suggest running the amp on your front speakers and running the rear off your HU if you only have a 2 channel. Most people would tell you to put it on the back ones because they (generally) are larger. But amplifiers aren't made to make speakers have more bass and be louder. They are made to Amplify, hence "amplifi ER", all the sound frequencies the source outputs. So why put it on the rear speakers. You drive the car right? Put it on the speakers you'll hear most of the sound from.
Old Jan 12, 2006 | 10:48 PM
p0rsche23's Avatar
p0rsche23
hmm ok i might do that,i only said rear but yeah its most common,or i thought,and it would be easier to mount another amp on the other rear seat....but still if i hooked up the rear ones to the hu would bridging them work and be safe,and sound better?..thanks u2
Old Jan 14, 2006 | 06:15 PM
seight311's Avatar
seight311
Simply put, no don't do it. Like pj said, even if it does work, yoiu'll probably run into more problems than its worth.
Old Jan 15, 2006 | 12:31 AM
p0rsche23's Avatar
p0rsche23
aight
jpplaw
Mar 19, 2025 08:53 AM
Epon
Oct 3, 2005 01:52 AM
JayCe
Aug 10, 2005 06:15 PM
ProStangs
North East
Apr 12, 2004 01:34 PM
