rain leaking in my 66
I think I'll get one just to keep out the leaves, but have them check to see what the problem is. The leak appeared to be right above the emergency flasher switch, as the water poured out from under that. They did tell me the cowl leak is pretty standard but they could fix it.
If I could have ordered the cover from the link provided, I would have, but it didn't like any of my credit cards.
the shop i took my car to has a very different way of fixing the cowl. they cut right over it, replace it and then weld it back on. so instead of removing the entire cowl, they do it without cutting up the weld spots. saves time and money
ORIGINAL: MustangPammie
bradleyb
Nov 27, 2015 07:50 PM
