Gauges
Old Jul 7, 2006 | 10:03 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Default Gauges
So im doing some "custom" gauges with the Z-Series gauges from Autometer.
This ist he bezel im going to use :
http://www.kanterperformance.com/htm...nt_cluste.html
(probably with the aluminum inlay)
the two 3 3/8 gauges are : Tach, Speedo.
4 2 1/16 im not too sure about, thats why im going to ask you guys
What I'm thinkin: Clock, Fuel level (definately fuel lvl hehe) water temp (which one!? 120-240 or 140-280?) and then fuel pressure or oil pressure but i dont know how many PSI for those. Which one do you guys think?
Oil or Fuel pressure? how many psi for those? and how many degrees for the water temp? Thanks guys!
Old Jul 7, 2006 | 10:09 PM
magic_man77's Avatar
magic_man77
Default RE: Gauges
Well, if you are not racing it, I would go with oil pressure. The gauge you will want to use is going to depend on if you have a stock oil pump, high pressure pump, or high volume pump. Your pressure range is probably going to be different enough that one gauge will not work sufficient for all 3 types.
Old Jul 7, 2006 | 10:11 PM
magic_man77
Default RE: Gauges
On water temp I would go with the higher one. Usually you will have a 180 or 190 thermostat in there. The higher one will give you a little better range since you are more concerned with anything over about 180.
Old Jul 7, 2006 | 10:21 PM
paladin_1888's Avatar
paladin_1888
Default RE: Gauges
oil pressure is a must, good range is 15 to 80 lbs. anything less than 15 is shutoff time and you dont want more than about 65 lbs even when cold, you can split oil filters if you are too high on oil pressure. Water temp range, I would use the 140 to 280 range, fuel pressure really isnt something that needs to be closely monitored on a carb engine, usually 5 to 9 lbs of fuel pressure to the carb is plenty. Fuel pressure is much more important to injected engines under race conditions, where you have pressures at injector over 500psi.
Old Jul 7, 2006 | 11:35 PM
EmperorOfChicken
Default RE: Gauges
I've figured out what gauges i need now thanks to you guys, BUT when im looking for a fuel lvl gauge, how many ohms 0-30? 0-90? Other? Thanks in advance!
Oh ya im also using www.egauges.com Has anyone used them? they are the cheapest i can find!
Old Jul 7, 2006 | 11:54 PM
EmperorOfChicken
Default RE: Gauges
Old Jul 8, 2006 | 12:44 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Gauges
If you are going with Auto meter they specify what guage to use on fuel. I think the cut off was Fords prior to 1987 and after 1987. I would go with volt meter, fuel level, water temp and oil pressure.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
