running rich
Old Sep 3, 2006 | 03:09 PM
  #21
cole18cars's Avatar
cole18cars
Default RE: running rich
FOUND IT. It was the power valve which was leaking. I used the washer which has a triangle shaped inner surface. I also used the new power valve. These two don't work together, just use the regular washer and the new power valve. Thanks to all with important info, I hope this might cure similar problems when rebuilding a carb. Thanks again
Old Sep 10, 2006 | 11:22 PM
  #22
cole18cars's Avatar
cole18cars
Back again, I installed 46 jets, as per pony carbs suggestion, runs great. Do I need to back of the timing? Should I just drive foe awhile and check the plugs/tail pipe? Thanks
Old Sep 11, 2006 | 02:21 AM
  #23
Colorado_Mustang's Avatar
Colorado_Mustang
Timing should be advanced for high altitude, anyway. Drive it and make sure it doesn't miss throughout the rpm range and doesn't ping. If everything sounds/feels good, just have fun.[8D]
Jb145700
Aug 21, 2022 06:37 AM
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
uedlose
Sep 10, 2015 03:30 PM
