Firewall/Torque Boxes
Old Sep 17, 2006 | 05:26 PM
c130nav's Avatar
c130nav
Default Firewall/Torque Boxes
Finally had some time to start working on the stang again, and have come to the point where i'd sure benefit from you'lls two cents.
Here's what i've got;
They're now tacked in place and I think i've done a fairly decent job of aligning the torque boxes by pre-fitting the lower vent cowling and the firewall, but how can I be more precise on these alignments???
Thanks
[IMG]local://upfiles/29155/0112ADC5CC524E0EADA1D0AB18CB781F.jpg[/IMG]
Old Sep 17, 2006 | 05:37 PM
valley firearms's Avatar
valley firearms
Default RE: Firewall/Torque Boxes
Wow! You will have a new car when you are done. There is a list of factory specs on the dimensions. I'm not sure if they cover the cowling and torque boxes. I know they cover the frame rails. There might be something in the FAQ section. I would also check another mustang and measure the width from outside of torque box to outside of torque box. Then measure from a point at the rear of the car to the rear of the torque box. Measure from corner to corner in a X pattern. This is how I would check the car. Make sure it is square or else the body panels will not line up. Trust me on this one. Good Luck. It looks great so far.
Old Sep 17, 2006 | 05:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Looks like you are doing just fine. Those torque boxes sure look big.
Old Sep 17, 2006 | 06:04 PM
c130nav's Avatar
c130nav
Does anyone know where to get a copy of the factory dimensions for a 67 coupe?
Old Sep 17, 2006 | 06:08 PM
valley firearms
Some of the guys here have the specs. Unfortunately I don't or I would help you out.
Old Sep 17, 2006 | 08:12 PM
THUMPIN455's Avatar
THUMPIN455
Ya should have measured before you took everything off. I woudnt weld them up just yet, tack everything in place, including the new frame rails and spalsh aprons then see where it sits. You are probably finding out now you need a reference point or everything will be off.. I hope you didnt throw away all the old stuff already.
OKay.. Since the 67 Cougar is up here we can get you dimensions.. Hell check your PMs we are gonna have to do most of this over Email and the phone..
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
mapitts
May 15, 2016 02:57 AM
daltron
Apr 28, 2016 08:10 PM
daytooday
Sep 20, 2015 10:55 AM
