67 Mustang I6 ?
Old Oct 14, 2006 | 03:00 AM
jus4ale's Avatar
jus4ale
Default 67 Mustang I6 ?
Water assisted choke
My fast idle will not release, now matter how long I run the car.
I am thinking adjust the choke spring tension, if I am correct turning cclockwise loosens tension, while clockwise will add tension,,,,,
So to allow it to kick off fast idle, would I need to tighten or loosen spring tension?
Tim
http://www.cardomain.com/ride/2449869
And sign my guestbook or tell me what you think here I would enjoy your feedback!
Old Oct 14, 2006 | 07:47 AM
DGA's Avatar
DGA
Default RE: 67 Mustang I6 ?
Most choke covers will tell you which way is lean
Otherwise first observe the cover for index mark and make a mental note of it ot mark it with a dab of nail polish
Loosen the cover screws and tap the cover to break it loose
move the cover back and forth and observe which way loosens it
Move it one index mark toward lean from previous setting and lock it up
If it is not enough move it one mark at a time until you find a setting that you like.
Old Oct 14, 2006 | 10:43 AM
Soaring's Avatar
Soaring
I ♥ Acer
You also have an idle adjustment screw. Look toward the rear of the carb, and on the linkage you will see the screw. Turn it counter clockwise to idle down.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
chain
Aug 17, 2015 08:52 AM
'stangdude
Aug 12, 2015 01:27 PM
daytooday
Aug 11, 2015 09:22 AM
