am i being thick?
am i being thick?
Looking at the two FAQ's for installing ignitor and they are slightly contradictor, i was told the va-mustang was the right way to do it as the other one seem far more complex, am i correct?
RE: am i being thick?
If you are sure you will always get at least 7.5 volts to your coil, then just hook it up to the coil and don't go around the pink resistor wire. In other words, just hook it up like the pertronix directions says to do it. However, if you want to play it safe, then get your 12 volts from the ignition like is stated in one of the ways to do it, therefore bypassing the resistor wire. That is the best way.
Cheers soaring, wanted to new the difference am going to try the pertonix way as have new alternator and new coil, flame thrower, so i think will have the juice. Paddy
ORIGINAL: 70coupe
i just put my kit on last week and hooked it to the coil...it works fine
SterlingStunner
5.0L V8 Technical Discussions
09-04-2015 06:28 AM
Blown00GT
06-15-2005 05:58 PM
