ignition kill switch
Old Jan 5, 2007 | 03:17 AM
  #21
atomsk680's Avatar
atomsk680
Default RE: ignition kill switch
or have a set of switched moujnted somewhere where, for example, you have to flip 4 switches in a certain order then turn the key to start
of course that would be hard to rig up
Old Jan 5, 2007 | 04:42 AM
  #22
Mustang Dad's Avatar
Mustang Dad
Actually its not hard at all, I did it to my 65 back in 68. You need 3 or 4 single pole single throw switches, wired in series and set so there is a pattern......up-down-down-up, or anything you want. When the switches are set in the correct order, current can flow and the ignition system isready to fire the engine.
Old Jan 5, 2007 | 06:28 AM
  #23
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
i would just put in the ignition switch and hide it
Old Jan 5, 2007 | 09:24 AM
  #24
sxs191's Avatar
sxs191
Just by 'The Claw.' One look at that and would-be theifsmove on (at least that's what the commercial says) . And it's stylish too.
Old Jan 5, 2007 | 02:10 PM
  #25
Brandontyler65
I ♥ Acer
i just had a though have any of you guys changed the oil on a 99(i think it is) GMC sierra in order to reset the service cycle in the computer you press the clutch twice the brake three time ans then the clutch then the gas or something like that so make your kill switch like that no one will get it LMAO
Old Jan 5, 2007 | 02:49 PM
  #26
grruminator78's Avatar
grruminator78
why not install keyless entry system and the remote and rig the shut off switch to that. So when you lock up "beep beep" your fuel gets shut off too
lincolnshibuya
Jul 5, 2020 03:05 AM
bradleyb
Nov 27, 2015 07:50 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
