intake swap pics
Old Jan 7, 2007 | 11:39 PM
baxsom's Avatar
baxsom
Default RE: intake swap pics
cool got a notebook going of info
i have an edelbrock performer intake and 500cfm carb coming
i keep reading about kickdown adapter and throttle cable adapters
now my questions turn to this mystery
first of all i dont have a throttle cable its a rod from the pedal to the carb
i have seen other mustangs that actually have a rod going from the carb to the tranny (it was a C6) that the carb linkage has to hit in order to put the tranny into passing gear.
again i dont have this my C4 is put into a lower gear by vacuum i am assuming because the only rod is the accellerator rod hooked to the pedal and if i unplug the vacuum line from the brake booster to the tranny it wont go into passing gear.
Old Jan 7, 2007 | 11:45 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Some early Stangs have the kick down on the lower part of the accelorator linkage, down by the exaust manifold outlet. What year is yours?
Old Jan 8, 2007 | 12:13 AM
baxsom's Avatar
baxsom
its a 68.
one of the early 68s that got a 289 in it
i know it has a cable from the tranny to the pedal down low like you cant see it unless you are under the car
Old Jan 8, 2007 | 12:20 AM
67t5ponycoupe
That should be the kick down
Old Jan 8, 2007 | 12:53 AM
baxsom's Avatar
baxsom
cool thats what i thought but that is the part that confused me
i dont see why that part should attach to the new edelbrock if it doesnt attach to the old 2bbl
or is that linkage adapter only for those that had the rodfrom carb to tranny already
thanks for putting up with the basic questions
summit racing was no help the tech there told me that all fords have a solid linkage that goes from the carb to the tranny
and i know thats not true because mine didnt and i knew i had a passing gear from somewhere
Old Jan 9, 2007 | 12:33 AM
baxsom's Avatar
baxsom
anyone else got any ideas on this
the kick down currently goes from the bottom of the pedal to the tranny
will i need to rig something different with my 4bbl since the factory 2bbl didnt need a kickdown rod from the carb to the tranny
Old Jan 9, 2007 | 01:53 AM
Colorado_Mustang's Avatar
Colorado_Mustang
No, you'll be fine. The linkage adapter is only for setups that had a kickdown connected at the carb.
Old Jan 9, 2007 | 07:45 PM
baxsom's Avatar
baxsom
sweet, thanks for all the help
totallly differant than
my first stang. itwas a 69 grande with a 390
it had the kickdown that went from the carb back
my dad tricked my by not attaching carb linkage so it wouldnt go into gear
once i found out the ruse it was like a whole different car
04stangman
Sep 17, 2015 01:45 PM
97SN95GT
Sep 13, 2015 09:45 PM
vintageaion
Sep 8, 2015 10:45 AM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
