Correct Time Setting
Old Jan 26, 2007 | 03:17 PM
gmata's Avatar
gmata
Default Correct Time Setting
Hello i took the distribuitor out of my car Yesterday and i had some trouble putting it back in im not sure if the time is set right but i want to do it with a Light.
Does anybody knows what is the correct time setting for a 67 Mustang 289 Engine 4bb Carb?
Thanks
Old Jan 26, 2007 | 03:23 PM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: Correct Time Setting
Probably about 8 degrees
Old Jan 26, 2007 | 04:03 PM
85lebaront2's Avatar
85lebaront2
Probably calls for 6, but I used to run 10 with no problems.
Old Jan 26, 2007 | 04:18 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
its for about 6-12 but you cannot be sure because every engine is diff you just gotta feel it and get your vacuum gauge out
Old Jan 26, 2007 | 04:19 PM
my77stang's Avatar
my77stang
the more the better without pinging, 8-10 is a happy place though
*edit* make sure your vacuum is disconnected from the advance and plug the hose so your not having a vacuum leak while trying to set everything
Old Jan 27, 2007 | 01:31 PM
69mach1377's Avatar
69mach1377
As much as possible without pinging, for all cars, ever!
drfister
May 3, 2018 10:38 PM
mirandaandjimmy
Nov 16, 2015 08:51 AM
gus_vb
Aug 29, 2015 11:35 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
