So it starts.
Old Mar 1, 2007 | 03:44 AM
Guitylerham's Avatar
Guitylerham
Default So it starts.
The drive selector is loose on my auto transmission. When I shift into drive, the handle is really loose and rocks back and forth. To go about tightening it, do I need to go under teh car? I haven't gotten the car home yet since I just bought it, but I noticed that when I drove it and now i'm just asking since that car is all I've been thinking about today.
Old Mar 1, 2007 | 03:51 AM
connor90's Avatar
connor90
Default RE: So it starts.
you have to order up some shifter bushings...theyre about $4 and easy to install
Old Mar 1, 2007 | 04:07 AM
Guitylerham
Noooooo, I didn't realize owning a mustang would be this expensive!
Old Mar 1, 2007 | 04:21 AM
connor90's Avatar
connor90
haha ya...i know. i just had to do this to mine. if i knew it was that expensive i probably would have never bought the car lol
Old Mar 1, 2007 | 04:31 AM
Guitylerham
Did you guys get under the car or did you go through the chrome shifter bezel?
Old Mar 1, 2007 | 04:47 AM
longlive289s's Avatar
longlive289s
ya i did this when i first got mine. i disconnected the handle from the tranny. the bottom of the handle is hooked onto a parallel (to the tranny) rod that u can unhook. just make sure when hook the handle back up it's in the same gear as when u disconnected it.....like, lets c....park? i messed that one up, couldnt figure out for a day y my car was all messed up[8D]
Old Mar 1, 2007 | 04:50 AM
connor90's Avatar
connor90
both...you have to get under the car to detach the shift linkage and then you can pull out the whole shifter assembly from the top. the hardest part is getting the shift lever off the pivot because they are pressed on. its only like an hour to an hour and a half project tops.
Ultrashock
Jun 20, 2007 12:46 AM
ProvingGrounds
Jun 14, 2007 06:09 PM
Sticky Mustang
Jun 12, 2007 08:26 PM
SikGT
May 9, 2005 04:02 PM
ONE BAD GT
Feb 9, 2005 10:39 PM
