So Close!!!
Old Mar 26, 2007 | 12:47 AM
PReal's Avatar
PReal
Default So Close!!!
Fordania is so close to starting up... but I have a couple questions.
1. For some reason I am not getting fuel.. Ihave a new mechanical fuel pump from autozoneand it a clear filter. I cannot see any fuel getting to the filter. Is it possible to put these mechanical pump on wrong?
2. If I get sick of a mechanical pump, I'm thinking about putting a universal electric pump on. I was thinking a universal pump and powering it via a relay connected to wire that goes to the positive side of the coil.
Are there any ideas on fuel system solutions?
Old Mar 26, 2007 | 12:50 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: So Close!!!
Yes, you can put the mechanical fuel pump in wrong. The pump arm must be under the cam. If you get an electric, consider the inside the tank models.
Old Mar 26, 2007 | 12:51 AM
66 stang's Avatar
66 stang
yeah, make sure that you get the bit that gets pumped under the cam tappet, or it wont turn it......
Old Mar 26, 2007 | 01:01 AM
PReal's Avatar
PReal
How do I make sure the arm goes in the right place.
I can see oil on the arm and there is a slight wear mark.
Old Mar 26, 2007 | 10:54 AM
PReal's Avatar
PReal
Bump
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
fastbackford351
Oct 1, 2015 12:24 PM
MusicCity615
Sep 12, 2015 07:05 AM
