Lights get bright...
Old Apr 25, 2007 | 10:30 PM
tyancey's Avatar
tyancey
Default Lights get bright...
The lights get brighter when I rev the motor. What could be the problem. I replaced the battery as well as the alt...
Old Apr 25, 2007 | 10:37 PM
350kmileFord's Avatar
350kmileFord
Default RE: Lights get bright...
No problem. The motor revs, turns the alternator faster, which puts out more volts, which makes the lights brigher.
One way to test an alternator: With car off, turn on headlights. Turn on car, lights should get brighter...
Old Apr 25, 2007 | 11:17 PM
JamesW's Avatar
JamesW
+1
On the early models, they had a 55amp (IIRC) alternator, that when idling didn't had a very low output. This was ok because the early models didn't have much of a current draw. When you rev the motor, the alternator output would go up and brighten the headlights.
It's not really a problem, but if you want to fix it..there are ways...(larger alternator, headlight relays,etc.)
Old Apr 26, 2007 | 01:08 AM
tyancey's Avatar
tyancey
thanks
Old Apr 26, 2007 | 01:19 AM
350kmileFord
This got me thinkin...
"I swear officer, I was doing 20 over so I could see better"
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
