65 won't start
Old May 11, 2007 | 12:12 AM
SilverSmokeGrey's Avatar
SilverSmokeGrey
Default 65 won't start
I have a 65 mustang 6 cyl. Im havin an issue thats intermittent. When you turn the key all you hear is the solenoid. I replaced the solenoid and the same thing happens. All the lights,horn,radio,wipers and everything works. When u turn the key the solenoid makes it noise and the starter wont spin or anything. Whenit first happened the car fired right up and ran for a bit, then stalled and nothing(just solenoid noise). the battery voltage is 12.2v.... maybe charge it over night? bad ground? everything is good. now what?
Old May 11, 2007 | 12:17 AM
connor90's Avatar
connor90
Default RE: 65 won't start
sounds like what happened to my truck when the starter went bad. that would be my guess
Old May 11, 2007 | 12:28 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
try tapping lightly on the starter case maybe its sticking?
Old May 11, 2007 | 12:34 AM
DenDen's Avatar
DenDen
I had some trouble like that and it was simply a loose connection on the starter.Your starter is getting juice as far as the solenoid.Use a test light at the starter to see if its gettingany juice when the key is turned.if the connector is tight,and you get power there,remove the starter and test it.It probably wont work.
Old May 11, 2007 | 12:59 AM
noroof66's Avatar
noroof66
Have you tried jumping it real quick? Could still be battery if you did not load test it.
Granatelli Sales
Jan 20, 2020 12:34 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
MusicCity615
Sep 12, 2015 07:05 AM
5.0 kevo
Sep 3, 2015 06:24 PM
