power steering problem ..help!!!
Old May 27, 2007 | 09:01 PM
supermanzx9r's Avatar
supermanzx9r
Default power steering problem ..help!!!
i have a problem the power steering pump cant move down farther on the bracket because of the pipe in the picture with the red arrow pointing to it how can i reroute that or is there a different pipe i can buy to over come this problem
Old May 27, 2007 | 09:05 PM
valley firearms's Avatar
valley firearms
Default RE: power steering problem ..help!!!
That's your fuel line. You can get a tubing bender and reroute it or just run a rubber gas line if you want the easy way out. Yes, it can be re-routed
[align=left] [/align]
Old May 27, 2007 | 09:11 PM
supermanzx9r
ok that is what i was hoping or can i buy a new fuel line that is already bent to clear the pump
Old May 28, 2007 | 02:47 PM
supermanzx9r
thanks valley firearms for the help you gave me yesterday, i was able to bendthe fuel line and now the pump can move up and down on the bracket ........you are the best ....and by the way my manual to powersteering is complete . and no leaks
Old May 29, 2007 | 12:49 AM
maverick75's Avatar
maverick75
i had the same problemwith mine yesterday i bended it and it worked but then i found out i need a new rad hose since its going to rub with the new ps belt...always once step forward and one step back [sm=headbang.gif]
jpplaw
Mar 19, 2025 08:53 AM
Urambo Tauro
Dec 17, 2016 03:30 PM
Cit95
Sep 22, 2015 07:08 AM
kdryan
Aug 29, 2015 09:57 PM
Tyoung68
Aug 25, 2015 04:31 AM
