Just when I thought...
Old Jun 10, 2007 | 03:01 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default Just when I thought...
It was all done, this happens. I think I have learned the truth about mustangs - they are never really "finished." [&:]
I got it all ready to go down to the inspection place and get a sticker, and I threw it in reverse, backed up for a 3 point turn in the driveway, put it in drive, and NOTHING. Apparently, last week when I changed the filter out on the tranny pan, it has been leaking ever since, and I was all out of fluid. No problem, I put some fluid back in it and re-park it. Now I have to ask - did the guy at O'Reilly's screw up when he said "no sealant is needed, just the gasket?"
Another problem I was having when doing that gasket was that I could get all 12 (or so) bolts to go in evenly at the same time. I did after a long time of frustration, but is there an easier way? And is there a specific torque I need to get the pan bolts to? I just sorta tightened up as I went, and when I went back today, I could get another 1/4 turn out of them.
edit: ach....just read the FAQ after I posted this and saw that I do need to torque 15-20 ft lbs., I did need some sealant, and I should have tested it a little more at the time[:@]
Old Jun 10, 2007 | 04:23 AM
andrewmp6's Avatar
andrewmp6
Default RE: Just when I thought...
depends on the gasket if its a cork type yes if its the rubber type no but i always use some just in case. basicly every nut in bolt on a car has a torque setting. id torque then fill it up and drive it see if it leaks any
Old Jun 10, 2007 | 10:14 AM
mySAVIOReigns
Rubber type
Old Jun 10, 2007 | 10:39 AM
Soaring's Avatar
Soaring
I ♥ Acer
I use the rubber and sealant and torque the bolts. I have never had a pan leak yet.
Old Jun 10, 2007 | 10:41 AM
mySAVIOReigns
I think I may just buy another gasket and do it over today.
Old Jun 10, 2007 | 02:35 PM
4reboy's Avatar
4reboy
I just had a cork gasket and I put all the bolts in then went around skipping each bolt, semi-tightening them all. then I went back and just hand torqued them until they were tight. I didn't use sealant and it didn't leak, but then I ended up having to get the tranny rebuilt, so it was all redone by the shop anyway [:@]
greenmeanie
Aug 20, 2013 11:40 AM
Shane 5.0
May 10, 2013 10:05 PM
USMCSKYLINE
Feb 6, 2013 01:25 AM
68MustangCoupe
15
Jul 24, 2009 04:27 AM
3.8_Special
Jul 9, 2007 11:51 AM
