intake manifolds question
Old Jul 28, 2007 | 05:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: intake manifolds question
Yeah, I had heard and read that the performer is not much more than a stockintake made out of aluminum, and that the RPM is superior for breathing. I was just curious about the difference between the RPM and the Stealth. You answered that question quite well. Thanks bro. It's guys like you who make this classic section one of the best on the internet.
Old Jul 28, 2007 | 05:53 PM
67mustang302's Avatar
67mustang302
I wouldn't give me that much credit. With all the newer manifolds and heads out there, I'd like to see a dyno mule shootout with decent heads/cam where all they change is the intake and see how it affects power across the range.
I also looked it up on the respective sites, the Stealth and RPM are both about the same height, but the RPM has larger runner cross sections, so it'd breathe better up top than the Stealth(but not for the reason I initially thought). I'd like to see how the newAction Plusfares against the RPM and the Stealth.
Old Jul 28, 2007 | 06:06 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Heck, my Victor Jr. idles better than my Stealth did...and that Victor is a single plane. Go figure.
Old Jul 28, 2007 | 07:14 PM
my77stang's Avatar
my77stang
^ we put a "performer" on my buddies 4.3 chevy V6 and it was single plane..... figure that one out?!?!?!
to me, from looking at the intakes i always thought the stealth looked like it was a idle-5500 intake, it just doesnt seem like it would flow as well as the RPM in the mid-top rpm ranges. but it was put VERY well that the new action plus seems to fill a gap between the performer and the performer rpm, and that may be the best way to go for the street. i may eventually snag one for myself and see how it compares to the ported RPM i currently own.
Old Jul 28, 2007 | 07:20 PM
67mustang302
I can't complain about mine, it drives really well, and makes power everywhere, and doesn't stop pulling past 6k rpm. Weiand seems to have a different design philosophy on intake manifolds than Edelbrock, though they both make very good manifolds
Old Jul 28, 2007 | 07:22 PM
my77stang's Avatar
my77stang
67 i wish i could take a ride in your car, as i am looking at a 570 for my 289 along with that weiand intake (eventually)
Old Jul 28, 2007 | 07:47 PM
67mustang302
Well, it went 13.440 @ 105.15 with a 2.159 60'(sorta crappy launch) first run down the track,and that was sucking hot air out from under the hood. I was also shifting a bit early to be on the cautious side, so I bumped my shift light up a bit.I'd like to get everything tuned out right, especially suspension which I tweaked the other day, and I just installed a hood scoop and isolated the air cleaner from the engine compartment, so hopefully high 12's before the end of summer. And it leaves stoplights just fine, drives great everywhere, gets decent mileage. And all with a 3.00 gear. For street performance it's a really nice setup, drives with manners. I can't wait till I can afford a 3.55 gear
As a daily driver it really does run great, and it's reliable
Old Jul 29, 2007 | 11:32 AM
mikethebike's Avatar
mikethebike
ORIGINAL: my77stang
i'd have to agree with mike here. i ran a RPM and love it. i will say that when i cut down the center divider (think of the airgap) i lost some on the bottom.
from what i see about the new weiand action plus intake, it seems like its an even better choice for a streetable 289/302/347
*edit* the weiand part number im referring to is the 8124, says idle-5500 but even their ad claims power increases over the edlebrock performer up to 6000 and if you look at it, it looks more like a RPM than a performer..... so i'll betcha it'll run right up to 6500-7000 and still be making good power
Cutting the plenum divider was a trick from the old days (50's/60's) that worked on the dual plane manifolds to extend the range above 6k. If you didn't go too far it didn't hurt your bottom-end enough to notice. I've seen some new units that have a notch cut in the divider and assume it is for the same reason. Just can't remember the model of the manifold. My 1967 Cobra unit is cut and the 427 Chevelle back in 1970 was cut down about 3/4". Never had them on a dyno, but it seems to work based on the old seat-of-the-pants dyno.
Old Jul 29, 2007 | 11:42 AM
my77stang's Avatar
my77stang
its the rpm airgaps that employ the divider trick, and the old school offys have a small notch between the back two barrels. i knocked mine down about an inch or so, and knife-edged it.
Tivo304
Aug 28, 2023 12:19 PM
Luke9222
Oct 22, 2015 11:55 PM
Mustangmalo
Sep 6, 2015 05:22 PM
Sep 1, 2015 08:16 PM
