overheating
Old Aug 23, 2007 | 06:06 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
Default RE: overheating
ORIGINAL: JMD
ORIGINAL: Mr. Classic EFI
Crossflow, as I understand it, Inlet and outlet are in opposite diagional corners. The staggered orificesprevent the coolant from taking the path of least resistence, as it would with both inlet & outlet on the same side. Orifice side coolant flows fast, no orifice side coolant hardly flows. Direction doesnt mater, Water dont like to go the long way.
??? Did I answer that or confuse it???
You answered it... but my top / bottom flow has the inlet and outlet on oppisite sides as well.... (70 351... left side inlet, right side outlet)
Will this do the same thing?
Fer sure, left right makes no difference, the principal is the same.
Just FYI,a double pass, is set up with inlet & outlet on the same tank, BUT with a divider between them.So allthe coolant feeds through the first half of the rad to the opposite tank side, then recrosses the rad to the second half of the first side. Double pass.
Hehheh, Clear as Mud???
Old Aug 23, 2007 | 06:07 PM
Vikefan88's Avatar
Vikefan88
i beleive i have a 4 row radiator...im goin to install that shroud and electric fan then test drive.... hope to see how it goes......any more ideas?
Old Aug 23, 2007 | 06:13 PM
67mustang302's Avatar
67mustang302
If you had no shroud that may have been it, but with a good fan if that 4 row can't cool your 347, then you need to get the radiator rodded out
Old Aug 23, 2007 | 06:19 PM
Vikefan88's Avatar
Vikefan88
yea im instalin a shroud and a electric fan in front of the radiator to turn on wen it reaches 190... ill test it and see hw it goes....hopefully good
Old Aug 23, 2007 | 06:34 PM
MrMischief's Avatar
MrMischief
i am having an overheating problem as well, i almost had to ditch in a parking lot to let it cool down. i do have the northern 4 row aluminum radiator and an electric fan, but a rebult oreilly auto parts water pump. i think the pump is a piece of junk. thinkin of ordering a flow kooler from summit for like $90 bucks. what do you guys think? oh i also already have water wetter in it.
Old Aug 23, 2007 | 06:54 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
what water pump are you using on the 347? also using a 185 stat(mr gasket) a 3 row rad and a standard flex fan with a shout will work great
if your using a electric fan what is the rating and is it an "S" blade fan..what is your timing set at? .. di you install your head gaskets right? did you perch you cooling system not need with a mr gasket stat
Old Aug 23, 2007 | 07:58 PM
67mustang302
Ah, yeah, head gaskets, I forgot about that. If you put them in backwards you get overheating. As for the radiators, I'm running a 3 core copper style with a flex fan and shroud with a high volume water pump, and even sitting in traffic in Bakersfield when it's over 110 out I have no overheating problems.
Old Aug 23, 2007 | 10:51 PM
JMD's Avatar
JMD
I am buying this tomorow,,,, the used one I had picked out was a little too thick....
This on is only 3.5" thick and produces 3.600 CFM,,, that is a lot of air my friends.....
http://store.summitracing.com/partde...art=HFM-ZFU16S
Old Aug 24, 2007 | 03:05 AM
IM RICKY BOBBY's Avatar
IM RICKY BOBBY
are you sure its not a 4 row copper that what most rads are. i have never seen a 4 row alum. im sure they could probably make one but your talking big bucks... the water pump wouldnt be a bad idea
Old Aug 24, 2007 | 04:52 AM
andrewmp6's Avatar
andrewmp6
water wetter is a great idea so is a overflow if you dont have one.do you know how many pounds your radaitor cap is
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
