wandering gauges
Old Aug 24, 2007 | 10:04 AM
66_grn_fstbk's Avatar
66_grn_fstbk
Default wandering gauges
Hey everybody,
I have a 66 2+2, that is essentially stock. Recently I have notices that my gauges (fuel, oil, and H2O temp) are all wandering in synch. Thus, I suspect some sort of voltage fluctuation. I know there is a constant voltage part in the dash, but wonder if this is the most likely bit to replace. Also if anyone has replaced this constant voltage part, are the aftermarket parts reliable??
Any help would be appreciated
cheers,
Old Aug 24, 2007 | 10:10 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: wandering gauges
no idea really, might be the IVR - (i think that stands for instrument voltage regulator?)
Old Aug 24, 2007 | 10:22 AM
67mustang302's Avatar
67mustang302
Yeah, prollya voltage regulator problem, or perhaps a short in the wiring for the dash that feeds all the same gauges
Old Aug 24, 2007 | 11:02 AM
connor90's Avatar
connor90
yeah, sounds like a voltage regulator. mine was loose so it was doing that, so i took it off, used some sandpaper to make sure there was a clean surface between it and the gauge housing and then screwed it on nice and tight. that seemed to fix it.
Old Aug 24, 2007 | 11:42 AM
LPlum's Avatar
LPlum
I agree with previous posts. The voltage regulator and or connections. This regulator is mounted on the backside of your dash gauge cluster. Good Luck!
Lowell
Old Aug 24, 2007 | 02:01 PM
JamesW's Avatar
JamesW
Start by checking the ground wire between the instrument panel and the frame. if it's loose/broken and causing an intermmittant, you'll get the gage drift downward then back up. Otherwise it's going to be the IVR going south on you.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
