Rare Option???
Old Oct 24, 2007 | 02:28 PM
  #21
Hawkins 812's Avatar
Hawkins 812
Default RE: Rare Option???
Im looking to add a middle console to my 69' coupe. Only one i can find is a universal one from cjponyparts. Id like to have some selections to choose from rather than going for the default. Anyone happen to know another shop that sells em ?
Old Oct 24, 2007 | 02:33 PM
  #22
dozierstang's Avatar
dozierstang
Woooww, wait a minute, is that what the vacuum thingy is under my dash. I did not even know I had tilt away column. I have a vacuum diaphram connected about half way down my column that has been disconnected for some time. I never knew that was what it was for. Learn something everyday. Guess mine came with more options than I thought. Does the wheel just slam over to the right when you open the door? Then you have to put it back into position? I noticed I had two switches on my door, just did not know what the second was for.
Old Oct 24, 2007 | 02:51 PM
  #23
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Yep. It is that vacuum thingy on your column. Many times those pieces are bad and need to be replaced. The pop-away function will not work properly without that piece. The tilt will still work fine though.
When the car is running, the pop-away portionshould not work. Only when the car is off should that work.
It goes up and to the right. Pretty fast too. Don't have your nose over the steering wheel when you activate it.
Old Oct 24, 2007 | 04:58 PM
  #24
superdavid's Avatar
superdavid
ORIGINAL: RolandT3Speed
The "extra" my car has is the remote adjustable drivers mirror. Whee....
Haha, mine has that too!
...and the super rare self destruct mode option it goes into by itself...
Old Oct 24, 2007 | 06:33 PM
  #25
6mustang6's Avatar
6mustang6
yeah man. thats the tiltaway. i figured it out by tracing wires, and pulling the rod which made the steering wheel pop away. i had always wondered what that second switch was too, lol.
Old Oct 24, 2007 | 08:58 PM
  #26
flickjo68's Avatar
flickjo68
not to ***** the thread, but how rare (if at all) is my 68 coupe with the "premium fuel" 302 4bbl, three speed, factory air, and a comfort weave bench seat?
Old Oct 24, 2007 | 09:19 PM
  #27
fastbackford351
Foghorn Leghorn
Kinduv an oddball combo I suppose. Not a bad combo at all, but nothing Earth shaking.
Makes me curious though. Do you suppose thebench seat was an option or was it the buckets that were optional? I'm guessing the bench was the option.
Old Oct 25, 2007 | 08:56 AM
  #28
RolandT3Speed's Avatar
RolandT3Speed
Bench was the option. That's why there are so few. Here's some production figures.
Old Nov 14, 2008 | 08:20 PM
  #29
WildMustang351's Avatar
WildMustang351
You tube video of 1967 tilt-away option
http://www.youtube.com/watch?v=qQRYBhuBwb8
Old Nov 15, 2008 | 05:02 AM
  #30
67 evil eleanor's Avatar
67 evil eleanor
The giveaway with the tilt away option is the second switch in the door jam. Often one is black and the other white. The other necessary item is the vacuum storage tank found under the front right fender. This stores the vacuum untill used and looks like a metal coffee can painted black. Often these are rusted and will not hold vacuum. If you have a tilt away and want to see if it works manually, then push the little metal rod about half way down and to the bottom right, push it toward the floor. Also the signal switch will allow the column tho tilt. "Dozerstang", look for a white vacuum cylinder attached to the column and also a electronic vacuum solenoid. Parts to fix these will be hard to find. The "bench seat" option is one of the rarest as far as interior packages.
jwog666
Dec 27, 2021 08:09 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Nov 18, 2015 01:34 PM
ChampInSD
Oct 2, 2015 04:55 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
