Engine tuning,, Problems..
Old Dec 5, 2007 | 10:52 AM
kalli's Avatar
kalli
Default RE: Engine tuning,, Problems..
completely forgot to say: as mentioned above ... if you're going for a bigger carb (4bbl), the you ned a diufferent intake manifold.
kalli
Old Dec 5, 2007 | 11:25 AM
boogerschnot's Avatar
boogerschnot
ORIGINAL: kalli
kalli
Ive got to run with what i have now,, until I can get the suspension and a few other needed things taken care of,, then comes probably a weiand stealth and a holley street avenger 570..
Old Dec 5, 2007 | 12:05 PM
Starfury's Avatar
Starfury
Once you get the timing figured out, you really need to pull a plug for inspection. As htwheelz mentioned, that stock carb is set up for manifolds and a stock cam. I'm betting it will run lean with your setup, and if it's running too lean you could burn a valve.
Old Dec 5, 2007 | 01:58 PM
boogerschnot
The cam is only a Performer Plus,, just a little over stock,, I will however get a new intake and carb as soon as my priorities are met.. and christmas is over..
Old Dec 5, 2007 | 03:42 PM
kalli's Avatar
kalli
yah i know. same here. have 100s of things to fix but some of them just have to wait.
if the car is still idling to high, check out the things I mentioned
kalli
Old Dec 5, 2007 | 11:44 PM
boogerschnot
Thanks Kalli,, Its idling just right now,, but the oil leak is driving me nuts,, Im going to have to park it until I get that solved.. Its the darn pan gasket at the curve, where it meets the timing chain cover.. First time it was the timing chain cover seal and now its the gasket at the bottom,, I never win..
djbigskrilla
Sep 20, 2022 01:04 AM
msavoia23
12
Jul 7, 2018 12:08 PM
drfister
May 3, 2018 10:38 PM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
Jacob4589
Aug 8, 2015 11:00 AM
