Beefing up a t5
Old Jan 27, 2008 | 11:11 PM
MonsterB's Avatar
MonsterB
Default Beefing up a t5
i checked the numbers on a t5 i purchased. it is rated at 265ft/lbs. 1352-169
should this be fattened up. im building a strong engine and my goal will be 4oohp.
Old Jan 27, 2008 | 11:28 PM
67mustang302's Avatar
67mustang302
Default RE: Beefing up a t5
Geforce makes a decent upgrade kit that'll take it to around 600ft lb capacity. Cheaper than buying a new trans, replaces all of the major components
Old Jan 28, 2008 | 06:23 AM
JamesW's Avatar
JamesW
ORIGINAL: MonsterB
Yeah, better now than finding it in pieces under your car later after a hard launch....
Old Jan 28, 2008 | 09:07 AM
Daze's Avatar
Daze
A z-spec T5 with a reinforced counter gear stabilizer will get you up near the 400 hp mark. The question is how will you be driving and what kind of rear tires are you looking at?? If you are drag racing with slicks than the only option is G-force, but if you are only a street driver who will occasionally dump the clutch than a Z-spec will work just fine.
Old Jan 28, 2008 | 01:27 PM
67mustang302
Yeah, the sticker the tires and the harder you launch/shift, the stronger the trans needs to be. The more the car weighs, the stronger the trans needs to be.
Old Jan 29, 2008 | 09:59 AM
fordification's Avatar
fordification
That was also my plan for my 390. But I was thinking a HD rebuild from ford racing which is ~$400, and my buddy has a good t5 case that he can rebuild.
I was kind of wondering how much more work it is to spread the gear ratios out. I know it must get steep $ switching out gears for aftermarket ratios.
Old Jan 29, 2008 | 12:54 PM
67mustang302
Geforce offers a few different ratios I think, their rebuild kit is around $1,000 and replaces the mainshaft, all the gear clusters etc, plus all the other basic stuff for a rebuild.
Mnuckolls
Aug 9, 2015 08:54 AM
mosnet23
Dec 5, 2005 03:10 PM
owned232
Jul 15, 2005 03:42 PM
