T-5 conversion parts PLEASE HELP
Old Feb 1, 2008 | 06:22 AM
JamesW's Avatar
JamesW
Default RE: T-5 conversion parts PLEASE HELP
what motor do you have and what flywheel did you get?
Old Feb 1, 2008 | 01:12 PM
PONYBOY65's Avatar
PONYBOY65
sweet
I have a 289 stock with 2-barrel carburator
and my friend gave me the flywheel off of his 66 3 speed manual transmission
would this work?
or should i consider buying something better?
thanks guys
Old Feb 3, 2008 | 12:45 PM
MonsterB's Avatar
MonsterB
THAT FLYWHEEL WILL WORK BUT YOU NEED TO HAVE IT REBALANCED FROM 50 OZ TO 28 OZ. THIS CAN BE DONE FOR ABOUT 75 BUCKS
Old Feb 5, 2008 | 03:03 PM
PONYBOY65's Avatar
PONYBOY65
awesome thanks for the help!
Old Feb 5, 2008 | 03:12 PM
PONYBOY65's Avatar
PONYBOY65
is this the same dust shield that JamesW is talking about?
http://www.latemodelrestoration.com/...1&comp=LRS
Old Feb 5, 2008 | 03:34 PM
66ckurt's Avatar
66ckurt
If you don't mind me asking how much have u spend for all parts including the actual t-5 and rebuild?
Old Feb 5, 2008 | 09:00 PM
PONYBOY65's Avatar
PONYBOY65
so far ive spent:
[ul][*]rebuilt T-5 transmission (including: bellhousing, clutch fork, and hurst indy shifter) 600[*]T-5 conversion package from ebay (Crossmember, fulcrum, slip yoke, and transmission mount) 310[*]rebuilt clutch pedal assembly 150[*]Cable clutch assembly 270
[/ul]TOTAL SO FAR:$1330
i have the clutch, flywheel, and pressure plate, but im considering buying them new.
still need:
[ul][*] roller pilot bearing, - Summitt[*]new flywheel bolts - Ford dealership[*]clutch attach bolts - Ford dealership[*]Flywheel[*]clutch[*]pressure plate[*]dust shield
[/ul]
Old Feb 5, 2008 | 09:06 PM
65Raven65's Avatar
65Raven65
I'm going to usethe MustangSteve kit, it converts to cable clutch, and power brakes all in one. Seems like a decent deal too.
Old Feb 6, 2008 | 12:01 PM
fordification's Avatar
fordification
the shield that mounts between the block and bell.
Old Feb 6, 2008 | 01:07 PM
PONYBOY65's Avatar
PONYBOY65
is there a different name for that specific shield because i cant seem to find it on ebay[&:]
thanks
