help with 66 289 heads
RE: help with 66 289 heads
ORIGINAL: Starfury
Fast66, when you port-match the exhaust, you're matching it to a gasket. You don't want to take it all the way out tothe gasket mark, you want to leave about 1/16" extra, but you're still matching to a gasket scribe. The idea is not only to remove the exhaust hump, but also to smooth the opening from the valve area all the way to the gasket surface.
When I did it, I just stuffed the ports chockfull of wet paper towels. I went in a good inch and a half with the die grinder and madethe port transition niceand smooth. After I was done I cleaned everything with liberal amounts of brakleen and compressed air.
Most gaskets are made larger than required and not necesarrily the correct shape, and when using the gasket porting method, you get a localised large port area which actually restricts flow. The best flow is achieved by a port that does not vary in diameter/cross section. (as much so a practical).
Definately grind down those retarded air injection LUMPS in the exhaust port. Totally unneccessary. Technically, my AFR heads are smog heads, but they just have holes rather than gigantic turds hanging into the ports. And port matching will really help as well, just make sure you leave a small overhang on the intake, and the head when going to the exhaust. IE you want the intake manifold exit to be just a bit smaller than the intake port on the head, and the exhaust port on the head to be a bit smaller than the exhaust manifold, like going through a series of openings, from smaller to larger. The minor overhang on street vehicles helps with reversion in airflow at low speeds, and will keep mileage and part throttle torque up.
Ooops, edited, I meant the exhaust port on the head should be a bit smaller than the manifold.
With all respect for youroriginal question, you don't really need to do anything to your heads to receivea reasonable return on your proposedperformance parts.
If you are reasonably happy with the performance ofyour car as it is now, you will be more pleased with your car once you change the parts.
Will porting your heads make more power? yea. Would Gt 40 heads make more power? yep. Would aftermarket heads make even more power? yep.....
Do you really need any of it? Given your goal of a little more performance I don't think so.
Go with your bolt ons, remove the air tubes. If you find yourself stilllooking for more power, change your heads! By going this route, if you later decide you need more power, as far as duplicate work goes, you will be out of pocket for a little labor, some gaskets,and probably a second replacement cam shaft.
The reason for the second cam is that the ideal cam for the stock heads and the ideal cam for aftermarket heads will not be the same.
