front leaf spring bushings
Old Feb 27, 2008 | 03:46 PM
dcohen's Avatar
dcohen
Default front leaf spring bushings
how do you get the front leaf spring bushings out? its for a 66 coupe and i have tried about everything i know short of melting the rubber and knocking out the thin metal sleeve
are these bushings even worth replacing or should i go ahead and get new springs?
Old Feb 27, 2008 | 04:01 PM
nassaubayman's Avatar
nassaubayman
Default RE: front leaf spring bushings
Front leaf springs? Never seen one of those. Could you attach a picture?
My '67 has rear leaf springs and front coil springs.
[8D]
Old Feb 27, 2008 | 04:07 PM
racin66coupe's Avatar
racin66coupe
hes talking about thefront of therear leaf's
Old Feb 27, 2008 | 04:21 PM
mySAVIOReigns's Avatar
mySAVIOReigns
lots of people have this problem - it takes about 40 sawz-all blades. Good luck.
Old Feb 27, 2008 | 04:40 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
I must be good, I only used 32.
Old Feb 27, 2008 | 04:47 PM
retro77's Avatar
retro77
Take a look at this site:
http://www.suspension.com/tips.htm
This guy has a ton of tips. The method on melting out might be the best one for you there.
Old Feb 27, 2008 | 04:52 PM
Oxnard Montalvo
I've heard an airhammer pops them right out also.
Old Feb 27, 2008 | 04:53 PM
TexasAxMan's Avatar
TexasAxMan
To answer your question, your old springs are probably sagging so you might want to replace the springs. The only way I know to get the bushings out is to burn them out with a torch, but wear a respirator and be prepared for a mess.
Old Feb 28, 2008 | 09:42 PM
Mustang Dad's Avatar
Mustang Dad
Changed the front bushings on our '65 about 2 months ago. Used a hydraulic press. It takes about 900 pounds of pressure (seemed like it anyway) to get the things to budge and then the springstend to fly all over the place when the pressurre drops off real fast. Installed a set of poly bushings and now ride real good. If you're changing the fronts, might as well change the rears at the same time.
Old Feb 28, 2008 | 09:56 PM
baddog671's Avatar
baddog671
Save yourself the trouble and buy new leaf springs. Most have them already installed..
jwog666
Dec 27, 2021 08:09 PM
b8checker
Sep 30, 2015 07:11 AM
mungodrums
Sep 28, 2015 10:54 PM
