Kickdown?
Old Mar 13, 2008 | 08:11 PM
prjct67's Avatar
prjct67
Default Kickdown?
Hello all, I am new to this andI am trying to put my baby back together. I havea 67 coupe with a 302. I was wondering doI need to put the kickdown linkage back on. WhenI bought the carit was not hooked up. Do I really need it? If so what does it really do? thanks for all the help.
Old Mar 13, 2008 | 10:28 PM
Scott H.'s Avatar
Scott H.
Default RE: Kickdown?
Old Mar 13, 2008 | 10:46 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I'd use it/ hook it back up..without it..it won't kickdown a gear based on throttle pressure at the right time..or at all
Old Mar 14, 2008 | 01:44 PM
bradleyb's Avatar
bradleyb
Doesn't the downshift cable that runs from the transmission to the throttle piece do the downshift? I thought the kickdown went to the carb?
Old Mar 14, 2008 | 02:51 PM
jlg2002's Avatar
jlg2002
You only need a kick down if you have an AT car. If you do, hook it back up as it helps the C4 determine the correct prsssures to use for shift points.
roneades
Dec 8, 2007 10:22 AM
84conversion50
Nov 28, 2007 01:34 PM
Hawaii 93 Stang
Nov 16, 2007 05:11 PM
dstanger
Aug 23, 2007 09:10 AM
Yonco
Feb 24, 2007 05:21 PM
