spindles?
Old Mar 27, 2008 | 11:21 PM
borsports's Avatar
borsports
Default spindles?
ok i need some help im kinda lost reading all this stuff i have a 69 i6 that i swapped to a 351w im going to swap to disk brakes do i or do i not need to swap the spindles???
Old Mar 27, 2008 | 11:58 PM
mightythor99's Avatar
mightythor99
Default RE: spindles?
best way to find out, is ask the guy you are buying the brake parts from,..............if it was a 66 or before, yes, you would have to,.........on a 69, i dont know. are your wheels 5 lug, or 4 lug? if 4 lug,.............DEFINITELY.............if 5 lug, then you've got a chance at using them maybe.
hope that helps!
Old Mar 28, 2008 | 12:20 AM
66JameStang's Avatar
66JameStang
This question would properly be answered by a person wit a sixty nine but, for a 66 the spindle swap is a must. I found spindles on ebay for up to a 68 but I did not find any on a 69. If the I6 setup is the same as a I6 66 then change em...
Old Mar 28, 2008 | 01:06 AM
67t5ponycoupe's Avatar
67t5ponycoupe
I know starting in 67 the spindles were the same between I6 and V8. I also know that the 69's with the big I6 had 5 lug wheels. What I don't know is if there is a differnece between the drum and disc spindles. Not much help I'm sure.
Old Mar 28, 2008 | 05:16 AM
andrewmp6's Avatar
andrewmp6
67-70 is the same v8 and inline 6 spindles only the 64-66 had different spindles.
Old Mar 28, 2008 | 10:58 AM
borsports's Avatar
borsports
i have 4 lug wheels now im confused i think im gonna just bite the bullit and get the new spindles just to be safe
Old Mar 28, 2008 | 11:07 AM
zmetalmilitia's Avatar
zmetalmilitia
Man, there are all kinds of different spindles for different years. I'm pretty sure if you have 4-lugs and are swapping from drums to discs, you will need different spindles. I think there is a difference between the drum and disc spindle, especially from 4 to 5 lug. If I understand your issue correctly.
Old Mar 28, 2008 | 11:53 AM
67t5ponycoupe
He does not need spindles to put disc brake on that car. Don't spend money you don't have to. Talk to your vendor before you buy, they will let you know what is going on.
winner99
Sep 30, 2015 07:04 PM
KillSwitchNY
Jan 10, 2006 12:38 PM
CrdStang
Sep 19, 2005 01:02 AM
67CarolinaCoupe
Sep 13, 2005 07:22 PM
eZ
Jul 13, 2005 12:53 AM
