seriously overheating ignition switch wire
Old Apr 6, 2008 | 07:33 PM
az1966's Avatar
az1966
Default seriously overheating ignition switch wire
black/green wire off the center tap of the igniton switch is warm as he88ll/ extremely warm, everything seems to work ok but the heat off the wire is crazy as in melting the insulation,,try'd chasing the wire back to the fuse box/light switch ,, and can't fine anything wrong or shorted,, any idea's ? pulling 14.5 volts at battery,, volt regulator thing? to high a amp rating on the alt? ( (60amp)
thanks for help/info really need it[align=right][/align]
Old Apr 6, 2008 | 08:02 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Default RE: seriously overheating ignition switch wire
You have a short somewhere.
That wire feeds a lot of stuff, the gauges through the constant voltage regulator, and the coil.
Do all the gauges work?
Go to the electrical section of the FAQs at the top of this forum and look over the wiring schematics.
Old Apr 6, 2008 | 10:06 PM
az1966's Avatar
az1966
everything works ok, best I can tell is that it hot's the the turn signal switch and then the main fuse block
jwog666
Dec 27, 2021 08:09 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Dathan
Oct 5, 2015 05:52 AM
Meystang
Sep 25, 2015 04:05 PM
Wombatnation
Sep 13, 2015 09:16 PM
