installing a timing chain cover
Old Apr 14, 2008 | 07:44 AM
krobillard's Avatar
krobillard
Default installing a timing chain cover
When installing a new chain cover, do I need to use that rubber seal that goes on the oval part of the oil pan?or use alot of sealent? Suggestions on keeping it from leaking?
Old Apr 14, 2008 | 07:52 AM
69thunder's Avatar
69thunder
Default RE: installing a timing chain cover
A thick bead of sealant works very well. Some people use the rubber gasket and some sealant too.
Old Apr 14, 2008 | 09:52 AM
boogerschnot's Avatar
boogerschnot
I used the little pieces that came in the timing cover gasket set.. I wish I would have gone with the one piece rubber gasket.. just make sure you get the crank seal on there correctly and lubed so it dont leak.
Old Apr 14, 2008 | 11:33 AM
ky's Avatar
ky
America ftw
we use the rubber pieces at work. but be sure to put extra silicone in the 4 corners. (shown in pic) red is where to put extra silicone. blue is where to put oil on the front seal.
drfister
May 3, 2018 10:38 PM
waid302
Sep 14, 2015 11:19 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
kdryan
Aug 21, 2015 04:01 PM
ding56
Aug 14, 2015 02:40 AM
