Warm Starts
Old Apr 26, 2008 | 09:45 AM
AscolA's Avatar
AscolA
Default Warm Starts
Hey guys,
My car starts right up when cold. I rebuilt the carb and upgraded the ignition last year. The car can sit for weeks and it will fire right up. However, when I drive it around and make a stop, I'll go to start the car when the engine is still warm it will stall when I put it into drive. I'll have to rev it a few times and it still wants to stall until I get going. Any ideas why it does this?
Thanks
Old Apr 26, 2008 | 11:31 AM
ky's Avatar
ky
America ftw
Default RE: Warm Starts
our carbd cars used to do that but our prblem was cause the carb was dumping fuel into the engine after we shut it off. itd flood pretty much.
but idk why itd stall.
Old Apr 26, 2008 | 11:08 PM
AscolA's Avatar
AscolA
Any one else have a similar problem???
Old Apr 26, 2008 | 11:11 PM
jwog666's Avatar
jwog666
choke sticking on maybe?
Old Apr 26, 2008 | 11:13 PM
ky's Avatar
ky
America ftw
ORIGINAL: jwog666
you have 1 too many spokes on your wheels
67mustang302's Avatar
67mustang302
Heat soak.
Old Apr 27, 2008 | 09:25 AM
AscolA's Avatar
AscolA
what is heat soak?
Old Apr 27, 2008 | 08:30 PM
AscolA's Avatar
AscolA
bump
Old Apr 27, 2008 | 08:44 PM
ky's Avatar
ky
America ftw
adjust the accelerator pump.
Old Apr 27, 2008 | 10:48 PM
67mustang302
Car sits, heat that normally is carried away in a continuous even manner by the circulating coolant, and air/fuel moving through the intake, now conducts slowly throughout the engine. Given enough time that heat migrates from the head just above the combustion chamber(which is VERY hot) into the intake and carb, the fuel gets hot and it's density decreases causing a leaner a/f ratio, and when you start it back up you now have a bunch of extra heat in the intake/carb/fuel with a lean afr that throws off combustion and the engine runs rough/poorly. Heat soak. One of the downsides to a carb, but usually if you hold the rpm up for a few moments it evens out. That causes larger amounts of fuel to move through the intake than at idle, the fuel being mostly liquid conducts heat out of the intake, and it also lets some of the cooler fuel from the fuel system get into the carb to get the afr correct. Extreme cases lead to evaporation of the fuel from the carb. You could try an insulating spacer.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
vintageaion
Sep 8, 2015 10:45 AM
5.0 kevo
Sep 3, 2015 06:24 PM
