head installation - ughh
Old May 23, 2008 | 03:19 PM
SalikDDD's Avatar
SalikDDD
Default head installation - ughh
ugh so today i was working on installing my new edelbrock heads and ugh.. i'm so freaking mad. i was putting em on and everything lined up correctly. the headbolts went in without a hitch, the new rocker arms went on perfectly, all the preload was perfect, everything was perfect. WHY DOES THIS HAPPEN TO ME?!?! ARGHHHHHHHHHHHHH!!
ha anyway - anyone else so used to something going wrong that when everything goes right you still get angry at it because you just WANT something to happen due to habit?
Old May 23, 2008 | 03:57 PM
ThanksDad's Avatar
ThanksDad
Default RE: head installation - ughh
I wouldn't know it's never happened to me.
I estimate time, money and frustration. Then I double it and usally come close.
Old May 23, 2008 | 04:50 PM
imnotmy77stang's Avatar
imnotmy77stang
dont worry, you havent tried to start it yet[8D][8D][8D][8D][8D][8D]
Old May 23, 2008 | 06:23 PM
ky's Avatar
ky
America ftw
i but you have no ptv clearance.
Old May 23, 2008 | 06:55 PM
67mustang302's Avatar
67mustang302
Good heads should be bolt on. My heads and intake actually are.
Old May 23, 2008 | 09:04 PM
baxsom's Avatar
baxsom
dont worry
it is going to drip one drop a water every 5 minutes of water out of one of the timing cover bolts.
that will make you feel better
Old May 23, 2008 | 09:18 PM
SalikDDD's Avatar
SalikDDD
heh, i don't know why it'd drip water out since i never had anything else off. had it cranked over so all is well
Old May 23, 2008 | 10:06 PM
ky's Avatar
ky
America ftw
how much ptv clearance you have? mine was minimal so i have to be careful and stay away from 6k rpms cause i didnt cut my pistons.
Old May 23, 2008 | 11:07 PM
SalikDDD's Avatar
SalikDDD
ptv is fine - there shouldn't be any issues up to 6500 rpm - i rev to 6000 constantly at the track with the GT40P's which had 1.84 intake valves. - plenty of people run larger valves then that on stockies and have no problems burning past 6000. - i just wont have use for going over 6k as my power dies out around there anyway. it was weird looking at the heads, both intake valves look the same 1.90 vs 1.84 but the exhaust was nuts going from 1.45 to 1.60 - hopefully the power increase will be worth the 1200.00 if not, they'll be for sale jk
Old May 24, 2008 | 08:40 AM
coda618's Avatar
coda618
Make you wonder if you did something wrong, doesn't it?
Luke9222
Oct 22, 2015 11:55 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
