Rising Hood
Old Jun 29, 2008 | 11:16 AM
valley firearms's Avatar
valley firearms
Default RE: Rising Hood
if the lubrication doesn't work it's because the pins and holes are worn. The pins get worn and the holes get oblonged. Maybe that's a sign of the previous owner taking car of the car, lifting the hood to often to check the oil
I had the same problem with mine before paint. It was even worse after I tried fitting the fiberglass hood. I purchased a set of re-pops and it was the same. It seemed the new hingitsos had the same slop. It's very difficult to tell until you get them installed because the hoods leverage is needed to properly operate the hinge. You may have to compromise bysetting the hinges a tad bit lower in the engine compartment when you install them.
Old Jun 29, 2008 | 11:19 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
low tension springs will fix this or remove them and use a prop rod
Old Jun 29, 2008 | 09:13 PM
4reboy's Avatar
4reboy
I had to have my hinges replaced, they were like "shimmed" or something (can't remember what the bodyshop said" so they weren't able to be adjusted properly and would stay up about a 1/2" in the rear
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Nov 18, 2015 01:34 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
