blower belt
Old Jun 28, 2008 | 10:34 PM
valley firearms's Avatar
valley firearms
Default blower belt
Since I put the 2" pulley on my weiand, it have been jumping teeth. Of course it's when it's hammer time. I have adjusted the tensioner all the way out and it seems tight. I can't go any tighter due to the tensioner being maxed out. The belt even seems pretty tight. Well, I need a new belt. Did I tell you you can run a roots style supercharger w/o a belt[8D]. I did a burnout leaving a car show today and threw the belt. It chewed it up pretty bad. I was able to get it back on and drive her home. The sideways burnout through second gear was worthy of a video, but no one got it. It is a ten rib belt. Has anyone had problems with belts and how did you solve it.
[align=left] [/align]
Old Jun 28, 2008 | 11:07 PM
67mustang302's Avatar
67mustang302
Default RE: blower belt
Roots are known for throwing belts when you turn up the boost. You may have to switch to a different pulley setup, wider pulleys. What type are you running now?
Old Jun 29, 2008 | 12:04 AM
valley firearms
It just the 10 rib V type that came with the blower.
Old Jun 29, 2008 | 12:10 AM
67mustang302
Might have to go to a Gilmer. Not sure if they have any that fit the Powercharger for the Ford though.
Old Jun 29, 2008 | 06:31 PM
LCC's Avatar
LCC
We run a Kevlar belts on the race car. We were going though a belt every three passes but the Kevlar one lasted a few events with out problems.
Some issues with shredding belts can be a misalignment with the blower and pulley and the engine hesitating or misfiring and causing a "jerking" motion on the crank. Another cause can be the blower has more drag on it then normal. It's hard to fix it over the net but we can try...
Old Jun 30, 2008 | 01:37 AM
valley firearms
[align=left]Thanks for the info LCC. There is no hesitation or misfiring for sure. She runs like a top. I think I shredded the belt when it came completely off or someone may have run it over. I pulled around the corner and didn't get the belt back until a kid brought it to me. He found it in the middle of the street.
I didn't start having these problems until I went to the 2" pulley. I'm sure it has something to do with the tension. I adjusted the tensioner out all the way and still get belt dust when I throttle it. Maybe the belt is whipping when I gun it. I have seen that the belt starts to jump on the tensioner before anywhere else. I get into the habbit of checking my belt after a hard run. Sometimes the belt is hanging off by one or two grooves. My belt is 48.25". I looked for something in the 47"-48" and it can't be found. Maybe I will try a 46 1/2" and go the opposite direction with my tensioner. I can set it back quite a ways but I don't know yet if it will be too small. Only one way to find out I guess.
ORIGINAL: LCC
[/align]
vargas
Jun 17, 2017 12:17 PM
FivePointToTheOh
Sep 29, 2015 12:53 PM
rafotree
Sep 22, 2015 03:55 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
