Rebuilding a C4 Trans?
Old Jul 14, 2008 | 02:11 PM
Piraya33's Avatar
Piraya33
Default Rebuilding a C4 Trans?
What is the typical cost of rebuilding a C4 transmission if I take it to a trans shop? Would it be easier/cheaper to leave it in the car and take it down there or should I take it out? I have no clue about transmissions. Thanks!
Old Jul 14, 2008 | 02:58 PM
muggsy's Avatar
muggsy
Default RE: Rebuilding a C4 Trans?
I took mine down to the trans shop and had them rebuild and put it back in myself..it was a performance rebuild (new clutches, bands, shift kit, 2400 stall converter, new high perf planetary, etc etc, allthe typical performance rebuild parts) and parts and labor were about $700.Hope this helps. It was the original 67 C4 trans.
Old Jul 14, 2008 | 07:20 PM
Gun Jam's Avatar
Gun Jam
Mine was 600.00 took them the whole car.
-Gun
Old Jul 15, 2008 | 12:58 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well if you want to learn the C4 is a very easy auto tranny to build. unlike most trannys that require special tools the c4 can be built with common hand tools iirc the most specialized tool i needed when i built my last c4 was snap ring pliers[8D]
Old Jul 15, 2008 | 02:27 PM
groho's Avatar
groho
if you do the R & R, a basic bench build is about $500. If you want a performance build you probably looking closer to $800 or $900. The performance parts = C-servo, hardened bands, extra clutches, modified valve body, stall converter, shaft upgrades, etc,all cost money. I believe you can get a stock rebuilt kit for under $100.The C-servo alone is over $100. A performance built C4 is well worth the money and can handle a load of hp.
Old Jul 15, 2008 | 02:30 PM
groho's Avatar
groho
BTW, I also pulled my own tranny,spent about $600 to have abenchrebuild, but spent at least$300 in parts. love it!
Old Jul 15, 2008 | 06:22 PM
Carlos Pineiro's Avatar
Carlos Pineiro
The best $50 I ever spent on my car was installing a tranny cooler. My oil is always bright orange and with regular bienniel service my C4 may not have to be rebuilt again for 20+ years.
Now is an excellent time to install one.
CP
Old Jul 15, 2008 | 07:17 PM
muggsy's Avatar
muggsy
Ahhhh good point...I also had a cooler put n as well at the same time that cost me a hundred or do if I remember correctly..
Pyrate Dave
Sep 10, 2015 07:30 PM
Mnuckolls
Aug 9, 2015 08:54 AM
monkeydude3
Oct 18, 2005 06:06 PM
inklvr
Jun 6, 2005 08:29 PM
mick023
Dec 3, 2004 12:00 PM
