Starts but then immediately stops...fixed!
Old Aug 7, 2008 | 11:48 PM
carefact0rzero's Avatar
carefact0rzero
Default RE: Starts but then immediately stops...
this same problem happened to me a few weeks ago on my first start after rewiring the car. i found the coil wire on the back of the ignition switch was barely making contact to the terminal. maybe that wire is loose on yours? or maybe its shorting out somewhere between the switch and the coil?
Old Aug 8, 2008 | 07:39 AM
Oxnard Montalvo's Avatar
Oxnard Montalvo
If you don't have 12v @ the coil when the switch is in the run position and you know the switch is good check the 12v feed(s) to the switch and the wire from the switch to the coil.
Old Aug 8, 2008 | 06:48 PM
David09sp's Avatar
David09sp
I am trying to follow these wired but I sware its impossible. What line colors should I be looking for.
Old Aug 10, 2008 | 02:49 AM
David09sp's Avatar
David09sp
Default RE: Starts but then immediately stops...fixed!
Thanks oxnard and care, found the problem, the wire has been hanging on my a few threads for awhile and I must of yanked it off when I was under the dash. Found the problem, was a pain to get to but got it, stripped and fused together.
Ahh what a relief.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
MusicCity615
Sep 12, 2015 07:05 AM
5.0 kevo
Sep 3, 2015 06:24 PM
