Headlight Switch Removal
Old Dec 7, 2008 | 11:28 PM
p25486's Avatar
p25486
Default Headlight Switch Removal
Hi,
How do I get the headlight switch out of a 73 mustang. The shop manual describes pushing a button through a hole in the dash and the switch comes right out.
There is no hole directly below my headlight switch, but I can get to a spring loaded button that is close to the edge of the dash on the switch housing. When I push the button, I can't seem to get the switch out.
Is it supposed to pop out? Or, am I supposed to unscrew the unit? I can't really see how the **** is going to pass through the dash opening without the bezel removed.
Thanks,
John
Old Dec 7, 2008 | 11:38 PM
4reboy's Avatar
4reboy
Ok do it right because I misread the directions and totally screwed up my headlight switch. If you feel behind the dash on the headlight switch there should be a small button, push that in and then the *** should pull out all the way. Once you have that **** out you can unscrew the middle piece with a big screwdriver or something. Unscrew that and then it should fall apart as it should since the front bezel and rear module are separated. Once you get the **** out it should be obvious what to do, but I was a dumbass and couldn't figure out what that little button did and tried to take it off other ways... wasn't gonna happen
oh and that's for a 69 of course, but it *should* be the same for yours
Old Dec 8, 2008 | 12:18 AM
p25486's Avatar
p25486
Default Thanks
That sounds right. Makes sense too. I couldn't figure out haw that little button was going to disengage that huge assembly.
I will try it tomorrow and let you know.
Should I replace the switch anyway? It's been in there for 35 years. Are the new ones any good?
Thanks,
John
Old Dec 8, 2008 | 01:18 AM
dcohen's Avatar
dcohen
unless the switch just looks really corroded and nasty i wouldnt worry about replacing it
Old Dec 8, 2008 | 02:05 AM
4reboy's Avatar
4reboy
If it works don't replace it, but on the other hand the new one I got seems to be very good quality and works great. The dimmer on it is wonderful and it clicks nicely into the position which turns on the interior lights... I didn't even know my old switch could turn on the interior lights! (but I"m not sure if I ever tried... haha)
Old Dec 8, 2008 | 11:48 AM
Nabster's Avatar
Nabster
My old switch turns on the interior lights.... about 40% of the time.
Old Dec 8, 2008 | 03:40 PM
p25486's Avatar
p25486
Well, my switch works great, so I guess I'll keep it. The restorer dude cracked the bezel somehow. So I'm trying to take it off so I can super glue the crack back together, then reassemble it.
Thanks,
John
Old Dec 8, 2008 | 05:03 PM
4reboy's Avatar
4reboy
Thanks,
John
I cracked a small piece on one of my bezels but luckily it isn't noticeable to anyone but me haha
Old Jan 4, 2009 | 12:52 AM
p25486's Avatar
p25486
Sorry I didn't get back sooner. The **** came out just as you decribed. Screwdriver from the front removed the attachment and the switch cam out neat and clean.
Thanks again!
StalkerGT
Nov 28, 2015 03:09 PM
jhawkr
Oct 30, 2015 01:55 PM
Colin Ringle
Sep 15, 2015 09:27 PM
wawagner82
Sep 13, 2015 09:02 AM
vintageaion
Sep 8, 2015 10:45 AM
