Ford 9" 3rd member thoughts
Old Jun 4, 2009 | 01:58 PM
67mustang302's Avatar
67mustang302
The True Trac operates the same way as any limited slip differential. But instead of using shims and a series of clutch packs, it uses a series of worm gears in 3 bores on each side of the unit, they respond to load from each axle and use friction within the bore to control differentiation. As a result you don't have friction clutches that wear out over time, so they last a lot longer than a clutch type. Carbon clutches are a much better choice in any clutch type LSD though, they last a lot longer. But with the True Trac you have hardly any moving parts, and you don't need any friction modifier. It's also a lot beefier so it's less likely to fail.
Diode Dynamics
28
May 26, 2022 12:02 PM
drfister
May 3, 2018 10:38 PM
squishbang
Suspension
Nov 2, 2015 03:42 PM
Jwoolsey08
Oct 2, 2015 08:42 AM
