any tips before I install vesailles rear end?
Old 06-04-2009, 10:10 PM
htwheelz67
htwheelz67's Avatar
Default any tips before I install vesailles rear end?
I'm getting ready to install my versallies rear end in my 67 vert, I am removing my brand new rotors and calipers also brackets etc...and 8" rear(for sale) and installing cobra brakes before I install it.
Has anyone had any issues with the versailles swap? Pinion angle? locating pin size? also what are you guys running for a M/C?
I have 4 piston front discs (stock type) and stock type booster I already have an adj prop valve installed to the rear.
htwheelz67 is offline
Old 06-05-2009, 09:26 AM
dodgestang
dodgestang's Avatar
Don't forget 3/8 spacers to use your existing tire and wheel setup.
dodgestang is offline
Old 06-05-2009, 08:33 PM
cprstreetmachines
cprstreetmachines's Avatar
And a Lokar e-brake cable setup if you still want the E-brake to work at all. It still won't work great unless you have another lever system like a center pull handle.
cprstreetmachines is offline
Old 06-06-2009, 04:57 AM
tx65coupe
tx65coupe's Avatar
I didn't have any issues with installing the Versailles in mine, but mine is a 65. The things you asked about weren't an issue for my car.
I am running a MC like this one.
http://www.mustangsunlimited.com/ite...sp?T1=1378F+01
You could probably just run a later model MC like the SN95 or maybe even Fox Body Mustang has.
I actually have trouble with my E brake. It works but not perfect. I hava to pull the brake handle out almost all the way to make them work.
What Lokar setup are you refering to?
tx65coupe is offline
drfister
05-03-2018 10:38 PM
Tyoung68
08-25-2015 04:31 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
Quick Reply: any tips before I install vesailles rear end?
